Race Box Beta Testing!!!!!!!!!!!!!
#841
I loaded the new software last night. My truck sounded so weird when it was idleing it was like skipping and knocking pretty bad but once I throttled up it was ok. Didnt have the same power I had with the stock tune. High Idle only went to 900 rpm and turbo timer does not work. Also still surges. Took the tune out
#842
#847
#848
OK. Seems to work just fine. Only stays on for about a minute. I haven't been able to drive it around as I have it hooked up to the 5th wheel. Things I did try:
1. Adrenaline set to PL00. Used Key to start and shut off truck. No Turbo Timer at all.
2. Adrenaline on PL4. Used Key to start and shut off truck. Turbo Timer lasted about 1 minute.
3. Adrenaline on PL4. Used key to start and shut off truck. Pressed Brake pedal killed truck.
4. Adrenaline on PL4. Used remote start to start and shut off truck. Turbo Timer lasted about 1 minute.
I will say that most of my issues with the turbo timer were after floggin the truck a little so, tonight I should have some more data after towing the 5th wheel 50 miles or so.
#850
#851
I'm waitin on mine to arrive. Just wonderin which tune it's going to have when I get it. Will it have the original factory tune that they go out the door with? Or do they get upadated before they ship? Just wonderin where I will be at for a startin point. Thanks.
#852
Hey Quad...did you adjust the last 10 level tune yet...I'd like to try it out but I'm out of town so I hesitated to download the most recent to the box, I'm not as savy about what to do if I have problems...?
#853
Well I tested out the high idle today and I have the same results as everyone else only idles up to 900 rpm. I have yet to have time to get the truck out and try out the upper levels to see if I still have surge but levels 1-5 have no noticable surge. I should have a chance to test it out this weekend. TT wont kill with brake pedal and when I turn the key off the truck dies and then picks right back up to idle. I don't know if that is normal or not.
Joe
Joe
