Race Box Beta Testing!!!!!!!!!!!!!
Old 11-02-2007, 08:21 PM
  #601
dodgediesel's Avatar
Looks like you will be waiting for a new module. Just call Quad and he will fix you up. I had the same issues and they sent me out a replacment, no biggy! It's all about the testing...
Old 11-02-2007, 08:31 PM
  #602
Crazydave's Avatar
The plug use decribed sounds like data link connecter. Its located by the APPS plug down by the vp on the drivers side front. It should have a plug in the end. So look for a plug that does not go anywhere in that area. Its the same connecter you would plug an EZ in. Hope this helps good luck
Old 11-02-2007, 09:14 PM
  #603
txsbigdaddy's Avatar
got the call mine goes out tuesday
Old 11-02-2007, 10:25 PM
  #604
1BAD4X4's Avatar
How hard is it to install? Never installed a box by my lonesome... I'm more worried about the EGT/Boost/Tranny Temp...
Any insight would be great!
Old 11-02-2007, 10:33 PM
  #605
CumminsRedneck's Avatar
im still waiting on an answer to see if they need more beta testers
Old 11-02-2007, 10:36 PM
  #606
IntakeRacing's Avatar
ahh crap... i leave town this week coming up for my dyno.. i sure hope i can get it 2 day rushed.
Old 11-02-2007, 11:19 PM
  #607
Very simple to install, that makes this box so much better than the rest!!!
Old 11-03-2007, 12:41 AM
  #608
wurkenman's Avatar
I never did one before either. There is a posting on this thread somewhere that says what wires go where. Not that hard, but the box comes with no paperwork.
Here is the info, it is on page 16 of this thread
Short Red Wire = Any fuse under the hood
Long Red Wire = Fuse #9 in the cab
Black Wire with Ring = Negative Battery Terminal
Dark Green Wire = Pump Wire
Yellow Wire = Fuel Pressure Sensor (Sensor Included)
Brown Wire = Transmission/Oil Temp sensor (sensor is included)
Orange and Black with 2 Pin Connector = Thermocouple
You also have a proprietary connection of the COntrol Pod, MAP sensor and Data Link and then the Main Big plug goes to the Module.
USB port is on the front of the enclosure behind the square seal. You can pop it open if needed, just plug it back in. It is built into the case so you cannot remove it totally and you cannot loose it.
The overlay on the COntrol Pod is for our X2 modules.
When looking at it the abbreviations will no correlate to the actual parameter being monitored. so here is a matrix.
Top Left = EGT
Bottom Left = Boost
Top Right = Trans/Oil Temp
Bottom Right = Fuel Pressure
If the LEDs in the corners are lit you will see PL0X (X= your power level)
You can watch any parameter you want and hit the up or down button at anytime, the display will show the power level change and display for a couple of seconds and switch back to the parameter you were watching.
PL1 = Timing Only
PL2 = Timing and Fuel Bus only 65 hp
Pl3 and Up starts really adding fuel.
Call 888-842-6572 and ask for Roark if you have any questions or troubles.
Old 11-03-2007, 12:49 AM
  #609
the pump wire is the top wire nearest to the block.
Old 11-03-2007, 12:51 AM
  #610
Yup, that's the one...
Old 11-03-2007, 04:16 AM
  #611
Mayhem's Avatar
What size tap is needed for the pyro?
Old 11-03-2007, 07:12 AM
  #612
yall that are having trouble with the tap get a blue posi-tap they work great have one on my truck now.
Old 11-03-2007, 08:26 AM
  #613
wurkenman's Avatar
1/8-27 NPT. Be careful not to take the threads too deep. pipe threads can be a little tricky if you are not used to them.
Old 11-03-2007, 06:48 PM
  #614
1BAD4X4's Avatar
Top Left = EGT
Bottom Left = Boost
PL1 = Timing Only
Greatly appreciated!
Old 11-04-2007, 04:09 PM
  #615
Crazydave's Avatar
OK box went in yesterday no problem. Trying to do my homework on it today, tried 3 different turbo timer tunes and all they do is leave the pod and radio on for a minute. I was wondering if you guys were having the same results? And whats the highest egt's you see when when running one of the defuel programs?
Quick Reply: Race Box Beta Testing!!!!!!!!!!!!!
