Race Box Beta Testing!!!!!!!!!!!!!
#571
I believe once all beta testers actually have a unit and installed and functioning. The next phases will come faster. Cause I believe Quad doesn't want to string out Beta if possible but get the bugs worked out and get to production asap.
Just my opinion though.
#573
ok my turn for problems! i got my comp update, installed it like i did the others and headed to the mountains for a quick hunt... well on the way up there i was getting power just not full power, i narrowed it down to the first two settings were working so i went straight to my wire tap, messed with it but i couldnt get the boxs higher settings to work, i even replaced the connector. when i got home i downloaded the file i was using before, 6 setting factory, and it ran fine. so that determined it was the file, this being the case i had cspotrun send me his and i downloaded his to my box with the same result... what i did now was delete all the comp files from my desktop/quad folder and re save the one chris sent me that way i make sure i did use his and re uploaded it to my box. i will find out in the morning if there are any different results.. quad can you please re-send me the comp file to luis.otero@nmkirt.ang.af.mil that way i can test it during the day without having to come home to check my email. thanks!
#574
Hey guys, what's the equivalent of level 3 on the 10 level tune?
#575
Ok got it working the fuse tap wasnt in good and I didnt see it until I took my fuse box cover off. Surging is kinda bad I got try and load the new software tonight whats the best one for power?
#576
Toss the fuse taps guys. You can't get it to seat properly due to the plastic molding interference where the fuse prongs seat. Forcing it will likely break a fuse. Snip the tap off and expose a little wire, run that down into the fuse seat along with the fuse.
#577
Isn't there a better fuse tap available...good idea but crummy fit?
#578
http://www.painlessperformance.com/w...rchField=70217
#579
UPS just dropped mine off, its going on tonight after work.
For those of you that hooked up the pyro and have a mechanical pyro... did you drill and tap a second hole in your manifold?
#580
I run a pre and post. Just put the Adrenaline probe to the manifold to utilize the defueling and the pillar gauge probe to the top of the downpipe. I wouldn't tap more than 1 hole in a factory manifold. You need to get an ATS or BD 3 piece manifold and then there's no worries bit the factory manifold is pretty weak. Hope that helped you out??
#585
Ok, before I send this to everyone, I need a couple of people that can give me some feedback pretty quickly.
I have version 1 of the competition tuning done. I like it but, it is going to vary from truck to truck. There is a lot of fueling happening. I mean a LOT.
So if you can get it downloaded quickly post up and I will send it to you.
Paul
