Race Box Beta Testing!!!!!!!!!!!!!
#392
Are you smoking more with the Adrenaline? It could be delivering more fuel than the Comp, your just not burning it all...and running hotter.
I run out of fuel with my Drag Comp and clear the smoke up completely with only one solenoid. I'm hoping to get the Adrenaline before the tracks close this year ......If the Adrenaline delivers more fuel for me to be able to use the second solenoid, I'll be a happy camper.
#393
Does this box shudder like the TST PM3 Comp does on the higher settings? My TST shudders so bad that I never run above 5!!! I think it's a useless box if I can't fully use it. By the sounds, the Quad Race Box doesn't shudder like the TST PM3 Comp and still fuels like a madman???
#396
ok guys.
Need a little help.
We cannot get the turbo timer to malfunction. I have seen it malfunction with my own eyes but, now it won't do it at all on our truck.
SO, we sort of think that it is/was a software compiling issue or something silly.
If you have this problem can you please tell us which update is causing this.
Also, on a different note, I am going to have an update later that adds 4 power levels for a total of 10 levels plus an off setting. Or 11 total positions.
WE are scaling it different so that PL3 does not hit quite as hard. The old PL6 will now be similar to PL8. PL9 and PL10 will be more. PL10 is 33% more fuel than the old PL6.
So I will be sending that out as well. If you don't want to mess with it fine but, if you do please let me know how you like it.
I am also going to have some options for defueling on more parameters such as boost and fuel pressure. I will send those out as well.
ANy and all feedback is appreciated.
For now, I am going to shut the website updates off until we figure out whether it is bad updates causing the turbo timer issues or not.
Need a little help.
#397
#398
The one you currently have and hopefully all the ones I send you from here on out will not have the surge issue. If not I have one that will for sure.
Now, with that said the more aggressive we make them the more likely it is for the people with bigger injectors to get a surge.
See I can make the same exact amount of MAX fueling act many different ways. Depending on the truck and your personal preferences we will have soft, mild, medium and aggressive files. They will all make the same power but, deliver it differently.
#400
#401
We are not done with beta testers. To be honest we have only chosen 1/2 of them at this point.
We just stopped as we are having a little trouble just supplying the first 1/2!!!
#402
Got some MPG numbers this weekend.
396 miles on 22.3 gallons ~17.75 mpg
About 250 highway miles. Close to a 100 miles hauling 12k and the rest in town driving/playing with a couple powerchokes.
Not bad with that towing thrown in there.
#403
I had the problem with the turbo timer not wanting to shut off my truck. I dont remeber exactly but i think it was the mild new one. Stan put it on there and i didnt have any trouble until a couple of times starting and killing the truck. We put one file on it and then decided to put the same one on there that i was having trouble with to see if it would still do it and after we put it back on there i havent had anymore trouble out of it.
Also im going to try a couple more times undating files and if I cant figure out what is going on i will either send the box in or wait until friday and just drive down there.
#404
11 on the fly selectable settings? even more fueling than is available on the highest setting right now? this thing sounds to good to be true Any word on what the "phase 3" of the box is yet?
