Quick wiring question...
OK, so I suck at wiring...I'm no EE
I'm going to run a holley blue pump off of the power window fuse in the dash (for now at least)...
There is no need for another fuse between the dash and the pump is there? Just want to know for sure before i mess anything up
i would just run power strait from the battery to a relay somewhere on the truck and then get power from where the stock lift pump get power to energize the relay. You could run a fuse between the relay and the battery. Make sure you know how many amps the holly blue pump pulls before you install the fuse so you know exactly what size to get. A clamp on ampmeter is espiecilly handy for doing this. i know i spelled that wrong
aggieengnr
06-09-2009 05:03 PM
HorseHauler
13
03-12-2006 11:48 AM
caleb c.
05-27-2005 08:19 AM
