quick question
quick question
this may sound stupid...but if i lengthen the injection duration via smarty. how will i benefit from this??? i been runnin torque management on 6 for a little while, timing on 3, and duration on 0. what if i run the duration on 5, how will it change? thanks in advance.
I don't know for sure, but I think that means the injector stays open longer (spraying fuel) into the cylinder. I think it's best to do this when the timing has been increased. You will get more fuel per injection pulse width. Which should increase power and heat. I may be wrong and if so, someone can correct me.
HorseHauler
13
03-12-2006 12:48 PM
hellotbone
18
06-25-2003 02:16 PM
soundbrz
11-20-2002 12:36 AM
