Quick ? about running with no plate ;)
just show them who is boss and let the smoke role!!!!!!!!!! I understand where you are coming from I have also been in a situation like this a couple of times.
98 12valve 3500 with a heavy flat bed on it....
that thing does smoke. cant wait to show my girlfriend what she likes to see... black smoke,,, w a car in it
Originally Posted by Forrest Nearing
with a stock AFC housing and arm, I don't see how the lever arm could go too far forward...
Well now i am kind of worried. I will fix it if it breaks but i dont want to fix something just because i wanted to have some fun. Is there anything i can do about the pin problem that would take care of the problem?
Rick
Rick
Originally Posted by infidel
A lot of people have said that before they came back with their tail between their legs and a busted pump...
12 valve, whether the arm hits the plate or not is a combination of rpm and load.
inline, grind your plate to #0, same results as no plate but no risk of damage.
the AFC arm becomes your "plate" so you need to adjust the lever arm so that it doesn't dive under the AFC arm and overtravel!
that's good info infidel. don't have a 12 valve, but it's nice to put a picture in my mind of what ya'll are talking about with the plate. I still hope this boy covers them turkeys with black smoke though. Had a bunch like that when I was in high school, stayed at my prom for 15 minutes then left and me and my best friend and our girls went out someplace far away from the "prep club"
Originally Posted by inline6359
How do adjust my arm for no plate? and if i adjust it for running without a plate then will i have to readjust it for my 100?
rick
rick
PS the screw can fall out.
Of cource you are. I drive "a weak *** old diesel truck that couldnt touch their cars" as they put it. I also cant afford to buy 24 low profile performance tires once they figure out it was me. I did think it would be funny to tie a piece of cable to a pole then to their muffler. Just a little frendly help.
Rick
Rick
i have heard of the don't remove the plate you will break some pin thing. but i have never seen anyone that has broke there pump because they ran plateless. i have heard all the storys about how bad it can be. i am begining to think it is a old wives tale. now i do run a plate to get a better fuel feed to the motor. i have no need to blow a bunch of smoke, that can't be satisfied with the injectors i run.
Originally Posted by 12valve
on the back of the pump, remove the pcover plate, then get a long 10mm socket, and loosen up the nut, then with a flat screwdriver, screw it out a few turns. retorque the nut.
Rick
dmill
12-11-2011 12:00 PM
kidsaturday
08-24-2009 10:51 AM
HorseHauler
13
03-12-2006 11:48 AM
banks twinram
02-05-2005 10:38 AM
