Questions on cold air intakes
I have been looking at the S & B cold air intake. Was wondering if anyone had put one on or heard any good or negitive about them. All so what is suggested. Don,t want to spent to much.
Thanks for any help and advice
The elbow from filter to turbo is a hard plastic piece instead of the accordian type I have seen previously. It would seem to me that a slight increase in velocity and flow would result from that configuration. Read about S&B's testing of their filter systems, you may be convinced as I was that it is a fine product. Besides, the clear plexi top on the new airbox has a cool factor that is hard to beat.
Injectors will probably next and I will stay on the low, conservative side as I tow 12-14k from time to time. It will also preserve other things like: tires, fuel economy, clutches, etc, etc. I know myself. If I have lots of power on tap, I will use it, just like my bikes.
I have an S&B intake and like it. When I first put it on my EGT's were the same as with the BHAF. That was to be expected I suppose since it only pulls air from the stock location. I went ahead and drilled a 4" cowl hole (ala Scotty) and EGT's went down about 200 degrees. I did not use the supplied hard pipe from the filter to turbo since I run a TAG. The filter itself does an awsome job. No dirt, no dust even after running 70 miles from the Utah border to Chinle Az in a dust storm that turned day into night.
patriot dodge
07-19-2006 11:01 PM
rattlbox
12-25-2005 12:56 AM
