Questions about Scout??
Questions about Quadzilla Scout??
Quad, or anyone else who can shed some light,
I am very interested in the Scout for my 2001 Dodge Cummins. Just a couple questions.
1. Does it, or can it be set up to activate the cold weather high idle-3 cyl idle feature on my truck
2. What is the additional charge for the performance & max mileage programming, fuel pressure kit, & egt kit.
3. Does it come with any type of mount, (e.g. windshield mount) or do I have to purchase the pillar mount.
thanks for any additional info
check it out here;
http://www.quadzillapower.com/produc...ex.cfm/p/Scout
2.)I think the performance unlock is $150. The FP kit is $90 like all of them!
For the scout itself, egt kit, turbo timer kit etc you need to get quoted from your vendor.
3.) It comes with a mount. It works but, its not that great. It is ok. The pillar mount is awesome! I have also seen it mounted on cell phone mounts and various places on the dash and that also works out very well.
thanks for you response qzilla, I sent you a PM
[QUOTE=qzilla;2373110]1.) With the performance feature enabled it will have high idle. Not the 3cyl high idle like from the factory but, you can enable high idle up to 1200rpm like on our XZT+ or Adrenaline
How does that work?, is it activated by air temp, or do you set it yourself thru cruise control button
