Question on fabricated intakes.
Old 04-12-2011 | 10:23 AM
jstone44720's Avatar
I have been looking at fabricated intakes, and while all different, they all seem to have a large collector or tank for the charge air, which then goes to the head. Why is that?
Old 04-14-2011 | 08:59 PM
HOHN's Avatar
Generally, this is there because it slows down the flow so it can make the turn a little more easily without separating at the inside of the radius.
It also dampens intake manifold pulses somewhat, but I doubt that matters.
Old 04-15-2011 | 09:32 AM
From somebody who should know . . . cool.
Thanks.
Old 04-15-2011 | 05:57 PM
Mike Holmen's Avatar
The Guru
You talking about machining off the intake plenum and building your own intake plenum? Doing this allows easy access to the intake ports. You can gain lots of air flow
The intake plate plenum cover stuff hardly does anything and isn't worth the time or money. I'm going to install a 6.7 intake plenum onto a 12V engine one day just to see if there is any improvement.
colt45d
05-17-2010 04:10 PM
iflyamphib
02-24-2009 03:52 PM
Special Blend
15
01-18-2009 11:25 AM
C-Chaplain
05-15-2004 07:13 PM
Cleaver
11-19-2003 07:19 PM
