question about edge vs comp
Old 11-11-2002 | 07:47 PM
j's Avatar
j
i'll be ordering a package deal from rip tomorrow (exhaust/edge or comp). as you can see in my sig i have an auto w/4.10 gears. i have been contemplating the edge vs comp arguement in my head for awhile. if i leave the pump wire off on the comp, how much does power increase? i probably wont use the pump wire til after my 7yr/100000 warr. is up and i only have 15k on it now. i've been leaning toward the edge for this reason, but will i get a little more power w/the comp and no pump wire hooked up? or will it be about the same as an edge if i dont use the pump wire? also once i have one of these can i use a j-hook to increase boost, or do i still need some sort of boost fooler? i know this topic has been here before, but i couldnt find the answers to my questions in the previous posts. thanks in advance all!!
Old 11-11-2002 | 07:49 PM
j's Avatar
j
Re:question about edge vs comp
by the way, i'll eventually make tranny upgrades way later on down the line!!
Old 11-11-2002 | 08:37 PM
chuck3's Avatar
Go with the comp it will save you from having to change to it later. With out the wire you should get 60 or so HP.<br> It has a boost fooler in it.
Old 11-11-2002 | 08:47 PM
phox_mulder's Avatar
[quote author=j link=board=7;threadid=6917;start=0#65304 date=1037062034]<br>also once i have one of these can i use a j-hook to increase boost, or do i still need some sort of boost fooler? i know this topic has been here before, but i couldnt find the answers to my questions in the previous posts. thanks in advance all!!<br>[/quote]<br><br>The Comp or EZ has the boost fooler to prevent an overboost code in the ECM/PCM.<br><br>The &quot;J-hook&quot; or &quot;boost elbow&quot; or &quot;turnbuckle&quot; or &quot;22 shell&quot; is to prevent the wastgate on the turbo from opening and thus allowing more boost to build, which would cause an overboost code if not for the Edge product interupting the signal.<br><br>If you don't hook up some wastgate solution, you won't see the full benefit of the EZ or Comp.<br><br>Do a search on the methods in quotes above to see what's and how's<br><br>phox
Old 11-12-2002 | 06:10 PM
j's Avatar
j
got the comp this morning... see my newest thread.... &quot;wife's gonna be ******&quot;, i decided after a little though that even if i dont use the pump wire i would still have an ez.
13jy831
02-25-2011 08:45 AM
lvmknsmoke..
08-13-2009 11:59 PM
mx684
13
07-24-2007 08:52 PM
JD farmboy
05-21-2006 02:04 PM
rockjeep73
03-25-2005 04:34 AM
