question about the BHAF
where can i find a bhaf for my 01 and whats the average cost? also, is it best to replace the factory intake tube with a smoother tube? i basically want to increase fuel economy because i regularly tow a 10' enclosed trailer. i would definately like a power increase but at this time im looking for effective but inexpensive mods. i'm a new 2nd gen. owner and im trying to get a feel for this great truck!
If you're looking for an effective and insexpensive mod for more power, better look at something else besides a BHAF. It's a waste of money no matter how cheap you can find it.
Under a tight budget...hands down, the best bang for your performance buck will be a used EZ or VA. They truely are effective.
wow this thread sure is shying me away from the bhaf, which i JUST ordered yesterday, oh well i'm still getting it, i wanna get rid of that POS k and n filter, they are no good to us CTDs.
what do you mean there was a rotten spot, did you have the outerwears prefilter on it too.
oh and by the way digbog, the link i posted will answer all your questions, if not, well, feel free to shoot.
i would still recommend getting one, especially for the EGT issue and such, just DON'T get k and n. many many, people will agree with me and the EZ, which i have, is great too, i'll give that to him, it makes your truck like night and day.
CLICK HERE
CLICK HERE
Go to www.fleetfilter.com and they have them for under $30. For the Wix brand filter it will be part # 42790. I like my BHAF because its paper so it filters well and there is so much surface area on it that its gonna flow a lot of air. It will make your turbo sing and you should see a difference in EGT's and MPG's. Yeah sure there is better intakes out there, but for the price its hard to beat. I hear good things about the Scotty II, but you will pay alot more for it. Just my $ .02.
Also, I would recommend getting some of that flexible plastic tubing that they usually have around battery cables and other electrical wires to put around your A/C lines. That BHAF will sit right on top of them and over time from the vibration from the engine and road, it could possibly wear a hole in one of them. I ran mine for a month without the tubing and I seen where it had marked up that A/C line.
Is the CTD well designed? The same engineers who designed the engine also designed the air filter. Do you honestly think they would leave 2 m/gal on the table with a badly designed air intake system? Lets be realistic about claims.
Increased filter area, or not, the BHAF dosen't flow any better than the stocker. Some brands flow less. It may filter a little better.
No one has ever shown it increases power in a controlled dyno test. If it doesn't show more power on the dyno how can you ever see it or feel it on the street.
And I'm still waiting for someone to explain how it reduces egts while it's using hot underhood air, even with a heat shield.
The only performance problem with the stock 2nd gen air intake is the rubber boot between the fender and air box. It tends to collapse. An effective mod is to remove it completely or strengthen it.
![Duhh](https://www.dieseltruckresource.com/forums/images/smilies/new1/duhhh.gif)
This may sound strange......
when I mounted my BHAF, I took the rubber grommet things (there are three) which had been used to hold the stock airbox in place. I then screwed them down over the bolts which held the stock airbox. This protects the bottom of the BHAF and adds about 3/4 inch of clearance so the filter doesn't hit the ac lines. I use plumbers tape to hold the filter in place (steel strap with holes in it) and when I build a heat shield I will probably create a mounting pad so I can ditch the plumbers tape. So far it has worked and there are no wear marks on the filter.
As far as flow goes...I honestly don't know...opinions will vary. My MPG did not change from the Kand N to this so I guess it flows roughly the same. At this point I am looking for good filtration without overwhelming noise, and it does the trick .
![Smile](https://www.dieseltruckresource.com/forums/images/icons/icon7.gif)
hey bart. being that im fairly new to to these trucks what what is the EZ and VA? still lernin.
Originally Posted by 01smoker
How do you figure that the stock airbox flows just as much air as the BHAF? Also how do you figure that surface area of the filter doesn't matter? It's like trying to suck air through a coffee stirrer vs. a regular straw, no comparison. Maybe you can't tell a whole lot of a difference, but Im sure there is a slight power gain. It still makes your turbo louder which most guys like to hear. And it's cheap. You can't hardly go wrong with a good Wix paper filter, that does a good job filtering, low maintenance, will flow more air than a stocker, makes your turbo sing, and its $30 bucks. I don't see how it could hurt the engine anyway so I don't know what the big fuss is about. Im happy with mine like most everyone else.
