QUADZILLA XZR-120hp W/Monitor VS Juice!
The new Quadzilla w/monitor vs. the Edge Juice w/monitor. They both claim 120 hp.
Geez, just when I though I wanted the Juice, this comes along (and the Hyperpac w/monitor too lol j/k).
Anyone have any thoughts?
Both are great units. The difference in the two displays is the Commander has a larger display, but you have to add a fuel pressure kit( somewhere around $65 extra). Both are rated for 120 horse,but the xzilleraider fuels to or above 3000 rpms and the juice just fuels to 2700. You can get the juice to fuel past 2700 rpms, but it requires extra cash for the 6th level and unlock code. The quadzilla also operates off of APPS signal. You can jumper two map sensor wires together and get the Xzilleraider to apply fuel as soon as it sees throttle applied.
Question on the last statement....is this like unplugging the MAP with the EDGE? I have read folks unplugging the MAP and talking about lots of smoke and more low end. Obviously it is dumping more fuel at low rpms.
Kinda the same, but you leave the map plugged in. You jumper the signal wire and the 5 volt wire on the Quad harness that goes to the map sensor. This makes the quad box think there is full boost signal and when it sees APPS signal it is fueling.
king5335
11-07-2009 08:53 PM
91rangerturbo
02-18-2008 08:26 AM
Stroked-Z
31
12-06-2007 11:44 PM
PG4x4
05-04-2007 02:23 PM
