Quadzilla Xzillirator
I like mine, but have a problem. I am waiting to hear back from Tech Support, but my truck runs rough when I have the module switched on. I can spray gravel in all gears with my dualy by mashing the pedal, but the rough running I don't like. I have read of some trucks with MAP sensor issues that can confuse the boxes, but it is rare. My IP is brand new/remanufactured, and everything runs smooth as glass with the module off, but really gets rough between about 1500 RPM's and up on any power setting. Like I said, I love it, but am waiting for replies from Quadzilla Performance to troubleshoot it. I also used a TST Stealth Cover to connect to the pump wire, rather than a T-tap. I have had bad luck with T-taps loosening over time, or breaking wires. I have had the box installed for only 1 full week now, and didn't notice any problems the first 5 days or so.
Thats the same issue I have, my truck is a brute with the box on, its a perfect stack with my Catcher, the power is smooth and is not violent like my TST, however the stumble when I turn the box on is a problem, I was told by tech dept that some trucks have this problem due to the IP having a different voltage that the box is reading, thus it is fueling at idle or its a timing issue, they are aware of the problem but im not sure how long it will be for a fix, I tried another box with a different serial # , however that didnt solve the issue, as far as communication it was pretty good, had to call a few times but Jeremy took care of me, like I said the box worked great with my setup, very little smoke, power came on smooth but once it started fueling hang on, installation was very easy, and once a fix comes I will buy another
Agreed. Installation was a snap, power feels great. I had a grin on my face I couldn't get rid of the whole time I drove! But that stumble...I don't like that part! I want to run on the 1st power level to gain some mpg's, but that stumble feels like a miss on a gasser, and is not pleasant. I hope they have an answer for it. The truck runs great now, with the new VP and Walbro, and I am getting to a point I want to really make it a bulletproof tow machine! I love the 2nd gen look, and have really gotten to loving the black!!
mopar440cu
11-21-2015 08:39 PM
norcaljr
13
08-05-2008 10:13 AM
Smokin98.5
0
05-29-2008 05:35 PM
FireNhole
14
02-06-2003 07:29 PM
