Quadzilla Xzillaraider Problem???
Old 09-19-2007 | 11:00 PM
cm979's Avatar
Ok I put the Quadzilla On my 99 CTD. I taped into the IJP Wire with the supplied terminals and Soldered the Wires, then crimped them both the IJP and the TPS sensor. Hooked up the Map sensor and ran the wires threw the Firewall, VERY carefully to make shure I didnt cut any wires and zip tied all of them away from sharp and hot objects. Well Hooked up the ground and put the power wire in the fuse box where they wanted it.
Turned the key on let the moduale make it cycle it was, red green green red. Was all good. Cranked the truck up check all my connections. Took it down the road, had power from the start I get about 6 or 7 Miles down the road to a store. Noticed my truck acted like it was missing. It all of a sudded cleaned up and when I have it on any level I have stock power untill 1500 RPM. Then BOOM it takes off. or if i am crusing on any power level and it gets to 1500 it starts to jump a little untill you get over 1500 but there is no different in the sound pitch of the engine when its at idle when you change power levels.
DOES anyone know what on earth is goin on?
Old 09-20-2007 | 03:29 PM
B-Peterson's Avatar
Mabe you have a program for bigger injectors in the box is it usb updateable? also check the ground wire. Hope this helps Ido not have any real expierence with these boxs yet.
Old 09-20-2007 | 08:02 PM
cm979's Avatar
No it has 3 settings. The top setting is 120HP 325 TRQ. It was working ok the first time I laid into it. I already sent it back to Quadzilla UPS RED they said they will road test and bench test after a reflash... Hope its fixed when I get it back.
norcaljr
13
08-05-2008 11:13 AM
usmcduncan001
09-14-2007 05:10 AM
jentas
08-21-2007 07:05 PM
riversidediesel
14
03-01-2007 12:06 AM
