Quadzilla Boost numbers??
Hey guys i finally bit the bullet and picked one of these modules up. One question though. Before when i had my edge juice i could spool easily 38 psi now with the quad i can only get around 30. it runs good don't get me wrong but just wondering if its because quad uses timing more instead of fuel? i have an adjustable elbow and i even closed it all the way and still the same thing. also my truck doesn't smoke nearly as bad as when i had my juice? I'm rechecking my pump tap tomorrow also just to make sure. thanks Mario
I have only run mine once with the Adrenaline and that was with a Beta Comp tune. With my juice I could hit my wastegate setting at 42 psi. I havn't really romped on it yet with the Adrenaline because that tune sucked and truck was stumbling and acting wierd. I did however notice that the control pod was registering boost pressure a lot later that my attitude monitor was and it seemed like I was having a harder time bringing the boost up. Like I said though I didn't go wide open with her either. I had a couple codes dealing with the map sensor after I installed the Adrenaline. Cleared them and havn't had them come back. I think I will hook up a manual gauge, take it out and compare the control pod reading with the manual gauge.
Fixed!!!!
i fixed the prob guys it was inside of the black module that you hook to you computer. there was a little white ectrode that was broken on te board i soldererd it and its perfect now!!!
dodgediesel
10-16-2009 11:28 PM
sCreamin400
11-02-2008 01:46 PM
norcaljr
13
08-05-2008 10:13 AM
Smokin98.5
0
05-29-2008 05:35 PM
steelblitzkrieg
33
07-20-2007 03:20 PM
