Quadzilla Adrenaline fuel psi reding.
I was running a Holley Blue fuel pump and was not sure of the output lately. PSI would fluctuate quite a bit. I just installed a Glacier Diesel Fuel Boss mechanical lift pump. The PSI readings still bounce all over. I still have the original pressure sender from the Beta testing time. I am guessing I need a new sending unit at this point. I am sure I have fuel since both pumps are giving me very erratic readings. Is there an after market sending unit or do I need to buck up and get the spendy one from Quad. I am fine either way, just trying to save a buck.
Thanks
Terry
Thanks
Terry
Personally, I think the solution is simple. Unhook the Quad and install an Edge.... I think the Quad senders are notoriously unreliable if they are the old ones. Don't know about the new spendy ones, though....
I know you can get a sender that will work with the Quad, but I can't remember what the voltage readings are. I think it's a 5 volt sender, but not sure. Any aftermarket oil pressure sender should work that is 5 volt....
Just got off the phone with the fine people at Quadzilla. I will be returning my unit and wiring harness for the upgrade. Quad and his staff have always been very fast to respond and very courteous.
mopar440cu
11-21-2015 08:39 PM
38 Cigarette
16
08-28-2015 11:27 PM
nrussell
07-23-2008 08:58 PM
Smokin98.5
0
05-29-2008 05:35 PM
Tommy93w350
08-07-2007 12:15 PM
