Quad Adrenaline Beta Testing....
Old 03-08-2008, 07:14 PM
  #1471
qzilla's Avatar
Originally Posted by Haulin Mutt
I have been testing out the updated 2018. The PL's still flash once I warm it up. Same as before, when I adjust the levels it stops blinking but once I get on it, it starts again. Good news though. The warm up mode works perfect and the TT does as well. My truck now turns off with the gas and brake. It did not do that with the brake before. My truck is an 01.
Thanks
Are you sure this is the updated tunes as of 3/7/08? I have not had a single flashing issue since we released them and in testing it fixed it for everyone!
Just making sure you got the latest as they have only been up since yesterday evening.
Old 03-08-2008, 07:29 PM
  #1472
stroker4501's Avatar
I just tried those today and downloaded them today also qzilla im about to try 2018 right now ill post to see if turbo timer works.
Old 03-08-2008, 07:35 PM
  #1473
Ok i just downloaded the 2018 and tried it and it didn't turbo time at all three times.mario
Old 03-08-2008, 07:42 PM
  #1474
just tried the high idle also doesn't work. i cant change mode either like before and just shows PL 0 not PL00 like before.
  #1475
Haulin Mutt's Avatar
I downloaded it twice today to make sure. I think I was one of the first ones to get a hardware upgrade. Is there something different in mine?
Model name: DADR9802
Serial Number: BETA0204
Software Version: 20080307
Feature Codes: ADR2018
Thanks
Old 03-08-2008, 08:48 PM
  #1476
Big Blue24's Avatar
Quad, I love the bottom end grunt of these Aggressive tunes. I have always struggled to spin the tires, now I don't even have to play with the clutch, just mash it good. This bigger turbo helps out a little too.
Old 03-08-2008, 09:04 PM
  #1477
qzilla's Avatar
Ok, PL 0 means you are in warm up mode. All the new tunes will show this when in warm up mode instead of PL00. You will not be able to change the settings while in warmup.
Regardless, the high idle and the TT should work regardless of warm up mode though. That is what I am working on.
Old 03-08-2008, 09:12 PM
  #1478
qzilla's Avatar
Thanks
Ok the other thing that can make it flash is if it is trying to de-fuel.
Do you have the Adrenaline pyro hooked up? I ask because I see your also have regular gauges and the 2018 file has de-fueling enabled on it?
Makes me wonder if the pyro is disconnected or something?
Your box is identical to the production boxes that are going out.
Old 03-09-2008, 11:00 AM
  #1479
I have disconnected my mechanical gauge from the pyro and have the plugged in the Adrenaline. It seems to be working correctly with that probe. It was a direct connection. Do I have to use the probe that was sent out? I have had the egts go high enough to defuel and the PLs will flash and work their way down as I get hotter and hotter. To get this blinking, I just have to go down my block and it will start flashing. I will still have power too. If it is a pyro problem, it does not seem to affect anything but the display. I will try a tune without the defueling and let you know how that works out.
Thanks
Old 03-09-2008, 03:05 PM
  #1480
hink's Avatar
Installed updated tune 1009 today. No flashing of PL's, High Idle worked fine, TT worked fine. No issues here.
Old 03-09-2008, 03:51 PM
  #1481
I just tested 2011. Works as advertised. No flashing, warm up worked, high idle worked, and TT worked. You must have been able to activate the brake turn off on the 01's? I am going to try another one with defueling.
Old 03-09-2008, 04:03 PM
  #1482
Tried 2012. It must be something with the EGTs. Quick burst in 2nd had the PLs flashing. With that little burst would only read 525 so something is up.
Old 03-09-2008, 04:36 PM
  #1483
RowJ's Avatar
If anyone has a problem with the TT or the High Idle on a 01 or 02 truck please chime in.
I do ...as already stated in post 1450.
High idle only works after fully warmed up and when I stop somewhere and leave it running. Goes to high Idle after 3 min (not two)??
RJ
Old 03-09-2008, 05:24 PM
  #1484
hink's Avatar
RJ
Hmm, my truck was already warmed up when I tried the 1009 tune, but it went into high idle after 2 minutes with the pod set on PL00. I will try it later with the motor cold.
Old 03-09-2008, 06:14 PM
  #1485
whitediesel's Avatar
Not everyone. I seem to have the same flashing issue, however it is only on the tunes with egt defueling. I thought mabey i had a loose connection
Quick Reply: Quad Adrenaline Beta Testing....
