Quad Adrenaline Beta Testing....
#1441
With the production tune and WOT it's smooth all the way. I get a very bad surge at part throttle (about 7 psi of boost).
Paul
#1442
Paul
#1444
#1447
The tunes are just updated to include the warmup flashing fix, the intermittent power on levels above PL07 and it also solves the problem where it goes to PL10 when it comes out of warm up if you mess with the buttons while in warm up.
#1448
Quad, this may seem weird, but can you tell me what pin the brown wire for the temp sender goes to on the main harness for the adrenaline? I had to blast through a snow bank a little while ago and apparently the weak link was the main plug itself and not one of my zip ties
#1449
I *think* it's pin 14. Is that right? Next question. Where can I get a metal plug that will fit into the adrenaline plug? Apparently it took the metal connector right out of the harness, and then that proceeded to fall off in the road somewheres.
#1450
Tried new ADR1003. No high idle. RPM tries to climb, goes to 925 after 2 min then settles back to idle. Tries again for 3-4 sec, settles back to idle. Keeps going like this.
Previous ADR1003 tune did go to high idle one time....after trying from 2 min to 3 min before going to 1200 rpm. Could never get to 1200 rpm again.
EDIT 4:30 - Went to store and left CTD running (new ADR1003).
After 3 min (not 2) truck kicked right up to 1200rpm. Tested this when I got home ...did it again??
RJ
#1453
I just tried the new tunes i tried Adr2025 , ADR 2024 and 2018 without any luck with turbo timing or high idle. Another question does high work when it out of warm up mode? thanks Mario
