Quad Adrenaline Beta Testing....
Old 11-25-2007, 10:55 PM
  #91
JDGnut's Avatar
Originally Posted by bnold
... I've already ran a dedicated ground...
Ok... I added a ground to the sensor.. just in case... No difference...
Old 11-25-2007, 11:08 PM
  #92
J Lent's Avatar
Originally Posted by dodgediesel
Thanks Ph4tty, that was an excellent day of running the rollers with a bunch of great guys like Morkable, Tate and Cranked Dodge. :
Congrats DodgeDiesel! The new numbers are with the Adreneline? What were your old numbers & what box?
Old 11-26-2007, 10:12 AM
  #93
RowJ's Avatar
And, What type Dyno?
RJ
Old 11-26-2007, 10:25 AM
  #94
Tiger Rag's Avatar
Any testers out there running a HRVP44 with the Adrenaline? Silly question but if so, is your idle lope still there or does the Adrenaline fix that??
I am but I've never had an idle lope with mine. No idle difference that I can tell regardless.
Old 11-26-2007, 10:32 AM
  #95
dodgediesel's Avatar
Sorry guys, pretty busy at work. That was with my Edge Comp Drag and Smarty #8. I was supose to get the Adrenaline replacment on the Friday before the Dyno but UPS figured I didn't need it till the Monday after!!! I'm so reved up to dyno the Adrenaline as it feels like a stronger SOTP box. It was on a Dynojet but I recently ran a Mustang and was at 548hp and 1004ft/lbs, so it's not too far off.
Old 11-26-2007, 04:39 PM
  #96
swmnkdinthervr's Avatar
380 miles today, about 50 of it in and around town...
No surging anywhere on any level...power was about the same as the last tune, maybe a little more timing down low or just my imagination
Still no EGT's high enough to test defueling...
TT worked on all levels today but was sporadic...didn't come on about 1 in 5 shut-downs, still unable to cut it off with either brake or accelerator.
This tune is extremely smooth but IMHO a bit underpowered, it's comparable to my old VA box with these injectors...hopefully any production model will have more punch
Old 11-26-2007, 04:45 PM
  #97
I think Quad's going to get the Adrenaline smooth first and then make it evil after!!!
Old 11-26-2007, 05:21 PM
  #98
I'm sure that's the case...while I'm committed to the testing I'm certainly looking forward to that day!!!
Old 11-26-2007, 10:36 PM
  #99
1-5-3-6-2-4's Avatar
geeze you guys will have all the bugs worked out before I ever even get my beta tester.........cool
Old 11-26-2007, 10:42 PM
  #100
actually anyone have the # to thier shop handy? I need to change my info they have on file.
thanks
*********Oh nevermind found it on the website
Old 11-27-2007, 01:04 PM
  #101
Well got the remote starter to work with the Adrenaline finally, my bad. The only way for it to work is to "not" run the turbo timer on my remote starter. This means needing the Adrenaline turbo timer set for longer than 20 seconds. I don't think my truck had enough time to cool down in 20 seconds. I'm thinking about a 1-2 minutes?
Old 11-27-2007, 01:21 PM
  #102
xtoyz17's Avatar
It depends on how hard you romped on it, the load it was under, and how recent it was. BUT I'd say 2 minutes would be good. 20 seconds is definitely far too short, I don't even think I see EGT's drop to 300 or so in 20 seconds after grandpa-ish driving.
Old 11-27-2007, 03:04 PM
  #103
I agree Shawn...
Old 11-27-2007, 03:48 PM
  #104
A new animal today again, right at 250 plus miles, mostly mountainous...TT worked only once at the end of the day after at least 12-15 shut downs...
Mild surging during minimal lugging in lower gears on levels 2-4 early in the day but seemed to smooth out (or I kept the "R's" up better)
I have no clue why this tune has a different personality from day to day, there are the variables in terrain: mountains/highway/city driving but I'd expect fewer differences...
Old 11-27-2007, 07:57 PM
  #105
bnold's Avatar
Sure you don't instinctively have the foot on the brake when shutting down??
Quick Reply: Quad Adrenaline Beta Testing....
