Quad Adrenaline Beta Testing....
Old 02-11-2008, 05:45 PM
  #961
dodgediesel's Avatar
Mine ran fine too but had the CEL on. Unpluged the Data Link, cleared CEL and all was fine. I don't think it makes a difference in performance but shows up as a error...
Old 02-11-2008, 05:58 PM
  #962
Tiger Rag's Avatar
10-4, sounds good.
Thanks all.
Old 02-11-2008, 08:46 PM
  #963
csrosenberry's Avatar
Hey guys still can't wait, but have a question regarding hp. What can a stock HO motor expect to see. I read that the box put down 165hp on a bone stock and 180 with a 62/12 turbo. But don't think it was a HO. Hope somebody can chime in and maybe get an awnser from quad himself.
Old 02-11-2008, 09:00 PM
  #964
SmokingFords's Avatar
I have a Ho and wanted to see what it would do,but i will be getting a So to put on shorty
Old 02-12-2008, 02:38 AM
  #965
1-5-3-6-2-4's Avatar
OK quad I've been battling this truck every step of the way this year. Sorry I've been lagging in the testing........so
Wasted the headgasket on the first official romp with the Adrenaline. It was pulling HARD, I mean HARD. boost was cruising past the 60 mark and I was only about 3/4 throttle. but between trying to keep it on the road..... and trying to keep it on the road I didn't get a firm look.
So the high idle for me was surging.... expected....no peddle kill..... expected (from 900 to 2000 to 900)
TT worked........kinda sucked when the headgasket was bleeding like a stuck pig and the truck wouldn't shut off though. No biggy though.
I'm going to get the head off and o ringed in an ASAP fashion. It has been kicking my bee-hind every single step.
But I swear its making some real power now., that was WWAAYY more than 510rwhp on the seat of the pants dyno.
Old 02-12-2008, 06:51 AM
  #966
RowJ's Avatar
Originally Posted by Tiger Rag
Really seems to run fine. I wouldn't have known it had I not seen the light.
Suspect that's the difference between a manual and an automatic. My electronic tranny was very confused till I unhooked both data link & adrenaline MAP plugs.
RJ
Old 02-12-2008, 08:16 AM
  #967
Tiger Rag's Avatar
RJ
Ah yes, I guess that would make a difference.
Old 02-12-2008, 11:45 AM
  #968
qzilla's Avatar
Is this on the original tunes? Or some of the current tunes you can download off the web?
Old 02-12-2008, 11:50 AM
  #969
this was original loaded tune. I didn't want to change anything till i got it run as is first. it was labeled 088 or 88 or something like that on a post it note. I just talked to Justin to update as well.
one other thing with my twin turbos and the EGT cable its just about 1 " away from being too short to reach my probe hole. its sort of laying straight across the valve cover and the probe side is snaked between my turbos and tthe manifold. if the harness side was 2 feet longer I could come all the way over to the passenger side and keep away from all the hot stuff.
Old 02-12-2008, 05:34 PM
  #970
nate_88's Avatar
has the beta testing form been removed from Quad's site? i tried filling it out, but it says that the page cannot be found.
Old 02-12-2008, 08:20 PM
  #971
blondeguy08's Avatar
Help
I got mine in today and hooked up but it will not monitor the boost pressure. What part of this unit does that? and they forgot the trans. temp probe. also its showing my oil temp at 100* all the time...... whats up with that?
Old 02-12-2008, 09:20 PM
  #972
paulb's Avatar
The map sensor connection is where the Adrenaline picks up the boost pressure. The "oil temp" is read from the trans. temp probe. No probe and it will read 100*.
Paul
Old 02-12-2008, 09:56 PM
  #973
thats weird....... its not showing the boost pressure......... the map is hooked up..... i don't have the trans probe but i did install the oil temp probe.....
Old 02-12-2008, 10:35 PM
  #974
Me too Demon. My EGT probe sure could be at least 1' longer. I'm stretching her to the limits. Are you going to make the March GTG now that you blew the headgasket???
Old 02-12-2008, 10:39 PM
  #975
I'm going to do my damndest to get it done and oringed in an ASAP fashion......so we'll have to play it by ear
Quick Reply: Quad Adrenaline Beta Testing....
