Quad Adrenaline Beta Testing....
#796
It went to everyone. I sent it to the entire email list. If you did not get it please let me know and send me your email address because I obviously have the wrong one??
On a side note the new tunes should be on the website tomorrow with even more options. I was confident in the new tuning but, not 100%. I am leaning that way a lot more now though and I will put out a bunch of versions with a lot of options tomorrow.
#797
#798
Quad...
I'm using the regular tune (BETA3_FT9) in this new box, (the one you most recently rushed to me to cure the shutdown issues) I'm now having shutdown problems with this new box/tune...now when I shut down I have to manually turn the box down to PL00 or I can't kill the motor...I'll be trying the aggressive tune later (ADR_BETA3_FT9_AGGR)...there are no surging issues and this tune is very smooth up to PL07, I can't really use any level higher without a bigger charger. (and "O" rings, studs...etc )
#801
I haven't had a chance to see if it will time out but I'll try after lunch...no the accelerator pedal will not shut it down unless I go to PL00...I can either go to PL00 and turn the truck off then tap the pedal or turn the truck off, tap the pedal and then go to PL00 and the truck shuts right down without further tapping.
#804
gotbutton@aol.com
Chbrown@cricketcommunications.com
#805
I would prefer you run the production tune but......there is no de-fueling.
If you want to test de-fueling I can probably whip something up for you and send it over?
You tell me what you want to test.
#806
I will run the production tuning, especially if it has defueling. I will load it up tonight if that is what you want, I'm your puppet bro, you choose the file & send it out to lent724@yahoo.com
#807
Ok, sent you a couple of options.
1250 de-fueling on both of them
Both have High Idle with 60 second delay
One of them has boost de-fueling set at 40psi. Just thought I would throw that kicker in there since you are towing?
no turbo timer because I thought you were saying you did not want one but, that was dodgediesel and for some reason I just confused you to.
Either way by lunch tomorrow or tomorrow afternoon the website should be full of tunes for anyone that wants to play with them!
#808
Also, on another note since I have been asked several times now.
This is for EVERYONE.
If your TT stuff is working fine and you don't feel like sending your box in, you do NOT have to. It is totally optional but, we are happy to turn it into a 100% production box. Not sure if you could even tell the difference or not but, the option is yours.
#809
#810
Let me know if it keeps working? I have no explanation for what was going on, just let me know if it does it again? Maybe it needed a hard reset or something?
