Quad Adrenaline Beta Testing....
Old 01-16-2008, 12:15 PM
  #586
lotero's Avatar
hanging tight, thanks for your hard work!
Old 01-16-2008, 12:17 PM
  #587
CTD01's Avatar
Made new pump tap. Messed with all the plugs and still have the same problem.
Old 01-16-2008, 01:38 PM
  #588
qzilla's Avatar
Do you have the old box still?
Old 01-16-2008, 02:30 PM
  #589
bigd450's Avatar
Would it be possible to ship USPS up to us in Canada last time UPS charged a 100 bucks for brokers fees.
Old 01-16-2008, 03:06 PM
  #590
paulb's Avatar
Quad, for what it's worth I have the same problem with no power. I have box 0100, so I know it's not one of the new ones, but it does have the no power problem. My connection is soldered to the pump wire....
Paul
Old 01-16-2008, 03:15 PM
  #591
JIT
JIT's Avatar
I too am part of the 2001.0 trucks that are not fueling!
Old 01-16-2008, 03:26 PM
  #592
BBA
BBA's Avatar
Me too i was going to go by quadzilla tomorrow but when I called I talked to justin because quad wasnt in yet and justin said dont worry about coming down there. So hopefully they have it figured out because that was probably my last day to make it down there unless I take off and it would have to be probably friday.
Old 01-16-2008, 04:27 PM
  #593
qzilla's Avatar
If you guys will read back a few pages I told everyone that we solved the no fueling issue.
As soon as we can get it uploaded there will be a new tune that should eliminate this problem. The software does not fix everything because we had some hardware we needed to change but, in the meantime the software should have everyone making power.
Justin should be contacting you guys individually about swapping your beta boxes out.
Old 01-16-2008, 05:55 PM
  #594
CTD01's Avatar
Any of you guys notice an idle quality difference
Old 01-17-2008, 12:28 AM
  #595
dodgediesel's Avatar
Can't wait for the new box!!!
Old 01-17-2008, 11:54 AM
  #596
bnold's Avatar
Just got my new box in today! Didn't know I was getting one... Will have it installed tomorrow
Old 01-17-2008, 12:28 PM
  #597
CTD01's Avatar
I have beta # 0063 I belive. Last night I soldered the injection pump wire. Then justin said the green wire to the pump will cycle between 50 and 100 volts I put my scope on it and put it on 5 milliseconds and there is nothing comming from that wire. Now the chip has been acting up sticking on levels and ow is stuck on zero. I'm driving a customers car today so I will see more about it tonight.
Old 01-17-2008, 01:29 PM
  #598
qzilla's Avatar
Ok guys, we have the new software up on the website.
This software should fix these following things:
No fueling above PL02 on some trucks namely 98-01.5 trucks
Ability to turn the TT off with the accel pedal
Surging
Now, if you were having issues with the TT acutally coming on this will not totally fix the issue, that is what the hardware change is for.
So, if you have one of the older boxes please go ahead and flash them with this update and it should get you by until we get you a new box.
If you already have a new box don't bother.
Old 01-17-2008, 01:40 PM
  #599
CTD01's Avatar
Hey quad what # is considered an "old box". I do not have any tt feature at all.
Old 01-17-2008, 02:59 PM
  #600
Dieselcamper's Avatar
Is there going to be a box in the future that will be
available with out built in gauges. I have all mech/analog gauges
and want to keep them. If you are going to produce a cheaper box
with out the digital gauges,I will hold off for awhile. Otherwise I'm
going to get a fueling box to stack with my Smarty.
Quick Reply: Quad Adrenaline Beta Testing....
