Quad Adrenaline Beta Testing....
#557
You can keep your analog gauges if you want. You might have to do a little engineering to make stuff like trans temp, fuel pressure and egt all work together or put multiple probes in??
You will not really be able to adjust tunes with the Commander but, you will be able to adjust features. You can turn certain features on and off like high idle or warm up. You can adjust warm up and defueling right on the Commander as well.
Also the Commander that is going in will take place of the Control Pod. It uses the same port to connect and that is the only connection needed for the Commander.
This Commander version does a lot more than previous version with tons of availabl parameters.
#559
Awesome thats great thanks for the quick reply. When you say adjust warm up what do you mean? I don't think you mean the high idle right you mean when the fueling is alowed to kick in.
#560
i do have a question i know that this box defuels on egts. does it also defuel based on boost say i want to only see 45psi can i set it up so it wont see more than that.
#561
#563
Can this box be run on its own with out all the gauges installed? Like a drag comp. I just got all my analog gauges installed and dont want to replace them or do new probes...
Also, as a side note we are contemplating having a download that will allow the Control Pod to show different parameters other than EGT, Trans, Boost and Fuel Pressure for those that do not want to hook anything up. Something like, IAT, Batt Volts, Load and De-fueling % or something of that nature???
The overlay will still read wrong but, we can show you what will be displayed where.
Valid or too confusing?
#565
My apologies on the answer for the boost de-fueling, I was told recently that would not be an option until furthrer down the road after the Adrenaline was put into production and new/custom tunes were available.
#566
Just thinking out loud.
#567
Quad, my new box is working as advertised. Thanks. It is serial number 204. You sent a new control pod with it. If the pod that I had looks exactly the same, do I need to swap it out? I would like to save the work for the Commander.
#568
Ok chips been good up until today. No added power over pl02. Checked pumped tap messed around with it seems to be all good. Now I noticed tonight when I got hom that even turning the chip on 1 idleing it would run like a small block with a cam. I called justin he said to try to update it also tried that same result. Fuel pressure is a rock solid 20 psi and no codes. What gives? TIA
#570
Ok truck was still hunting this morning so I shut it down and unplugged the ip tap and the truck still hunts but not as bad. Even with the chip on run the idle is still a little funky. I'm confused all other connections ok.
