Quad Adrenaline Beta Testing....
#437
Your doing a great job quad. Even though my clutch and vp are dieing, I love this programmer. I can not wait to get a clutch in to really push down the pedal.
My v300 tune was not fueling either just as an update. But the web page tune sure is "kickin".
#438
Anybodys 01 seem to not be fueling like these older model trucks? I have a couple buddys that have ridden with me and swear up and down that powerlevel 2 feels stronger than 10. Or is it our minds playing tricks on us?
#439
Are you sure it is fueling above PL02. Power level 10 is no comparison to PL02 in my truck. PL02 is XZT+ level. Are you running out of fuel? Possibly bad vp44? My Fass 150 gets pulled down to 7psi wot. Have you tried level PL08?
#440
when mine does the non fueling above level 2 thing i just watch my EGTs, if it wont get above 1100 degrees then yea its not fueling. and of course smoke and massive power difference is also an indicator.. it should be night and day.
#441
Keep up the good work Quad. I'm super anxious to rock the new tune as soon as its ready to go.
#442
My 01 fuels like a banshee!! The EGT's will for sure tell the truth like Luis said. . My truck sounds like a whole different monster when it's got full fueling. There is a problem for sure if you can't feel a difference between PL02 and PL10.
#444
Yep, my '01.0 does not get fuel above PL02. Smoke is way down and clears up even with Jammer 5's and my EGT's arent rising like before. The smike didnt clear up even at WOT in O/D with the original tune!
#446
I felt like playing today & decided to throw Smarty back on to see how it stacks with the Adrenaline. It works well on sw2 with the Adrenaline on any settings. It feels like it has more mid range power, but not too much difference up higher in the power band. Overall, I like it.
#447
I just love how the Adrenaline doesn't smoke as much as the Smarty/Comp stack. I tried the Adrenaline/Smarty stack a little while ago on SW#4, 6, and 8. Way too much surging going on and it totally kills the defueling which kinda sucks. These 2 animals don't play well together as they probably are fighting to do the same bottom end fueling thing???
#448
#449
My 01 does not fuel hard at all with the v300 program. I feel like my truck pulls better with just injectors than it does with the v300. The other day with my box on pl08 my buddy busted my *** with just his mach 3s.
#450
My truck cant be fueling like it should. I decided to Like be speeding up not WOT but just speeding up started on 0 and went up I could feel the jump of power wen I moved it up to 1 and felt more on 2 and after than I couldnt even tell when I moved the power level up. Im not a 98-00 or I could drive down to quad.
