Quad Adrenaline Beta Testing....
#361
Justin sent me some files to try, but he says they were made for 01 up trucks. They didn't fuel on my truck, but it was suppose to fix the shuddering problems. I asked about the TT not shutting off with the brake pedal & he told me to just try hooking red wire with white stripe in the cab to fuse #9. If that doesn't work he said to just disconnect the same wire because its only purpose is the turbo timer.
Not sure which program you are using.. When mine was acting up.. you could pull the wire to the F9 fuse. and it would kill the engine.. but as soon as you plugged it back in the circuit was powered up again.. I had to remove power to the box.. or unplug the box... I haven't had this issue in a month.. or two.. since the 300 tune..
Bryan
#362
Bryan
Bryan
#363
I tried the v300 tune, everthing worked well, but it didn't fuel past PL02. I've tried a few other files & only one that fuels is the one on the website. Problem is that it surges between 1800-2200rpm. The high idle doesn't work & the TT won't shut off for 3 minutes, pedal don't delete it. I have my red/white wire on fuse #17. I'm gonna try #9.
#364
Yep, that should fix ya up. Hope everything works better for ya now. Let us know it that fixes it. BTW, sometimes when I don't want the TT to run, I'll hit the brake pedal as soon as I shut the truck off to kill the TT and the motor, well, that messes it up. If you don't want the TT to kill the truck, then shut the key off and wait about 5 or 6 seconds before ya hit the brake or gas pedal and it should work fine. If you hit the brake pedal immediately after shutting the ignition off and it doesn't die, then turn the key back on and wait a few seconds for the TT to activate and then hit the brake or gas pedal. At least I think that's what I've figured out.
#366
Welp, got the pump tapped today. Holy Crap, my POOR HY35 and 35psi boost gauge, they took a beatin. Could max out a little over 1400 on PL10, I didn't think that was to bad for the HY. I have no idea what my boost #'s were, the needle flew past 35 and was pointin straight down on the guage, I'm guessin about 45psi--WOOPS, I better loosen up the J-hook a litlle!! Boost gauge doesn't read over 16psi on the Recon, anyone else have a problem with that?
#370
Believe it or not, my friend started my truck today & I walked out & forgot to swap it to #9. I got in the truck, headed to town & forgot to try it out. I am gonna have to try it out tomorrow, wife has me working on the house today finishing a few touches to the rooms that we just remodeled & I'm about wooped. Good thing is that I have 7 rooms & a hallway all done. Bad news is that after the holidays I have 7 more rooms to remodel Then outside work in the spring.
#372
Yep, all is good. I'm hopin they get the boost reading figured out, I sure would like to use the boost de-fueling since I'm goin to the dyno on Jan. 5. It would be nice to have the boost de-fueling when I get on the dyno since this thing winds up so fast when it kicks in. I haven't got the j-hook loosened up yet, I guess I'll just have to regulate it that way. Kind of a pain in the butt gettin to that thing though.
#373
Oh yeah, got the high idle workin, didn't know it had to be on PL00 for it to kick in. Idles up to about 900rpm after about 30-45 secs. then slowly works it's way up to 1200. Awesome!!
#375
We have totally new tuning coming out. We are just working on it. We found the issue with some of the fueling issues on the 98-00 trucks. For now the only one that will fuel past pL02 is the one on the website. The new one will work fine.
With the Holidays give me just a little time as we are working hard on it.
