Quad Adrenaline Beta Testing....
#332
I cannot feel a difference between level 2 and any other higher levels. I also have a 99 and have updated to beta 300 tune. That said, level 2 on the v300 tune feels nearly as powerful as level 3 or 4 on the juice, Quad must have some serious bottom to mid level fueling hit via the can bus to make my truck feel so strong without much wire tap input of fuel.
Also can't get this box to smoke out intersections like I could with the HOT Juice when I purposely lugged it with accelerator on the floor.
#333
Oh, almost forgot, when I turn my truck off, key fast or slow, truck nearly dies then surges hard as it catches itself to go into turbo timer mode. Just to compare, with the Juice turbo timer, you could not tell that key had been turned off when it's turbo timer kicked in, the truck would just purr like when the key was on. Neither Clutch, Brake, Accelerator, or E-brake, or any combination of the four will shut off truck before the 20 second turbo timer.
It would be great to have an egt based turbo timer, set to 350* or so, with a timed automatic shut down after a few minutes if target egt is not yet reached.
On my truck, there is no sign of surging in the least bit. There were times with the edge juice that it would surge a touch at 1100 rpm, high gear, low speed and too much throttle. But one would expect a vehicle to surge under those conditions. Quad, your Adrenaline has made my idle smoother, take off smoke less, eliminated all surge under any conditions. My hat's off to you Quad, for driveability, the Adrenaline is better than the "smooth" edge modules. Mid range is better than anything I've tried. Top end will have to be determined later when race tunes become available.
#334
lent,
I am still running the stock clutch. POOR clutch. To make matter worse, I got the 0216 code today. Time to get that vp44 before a clutch and new tires. The list gets bigger and bigger.
#335
My 01 is not fueling on the V300 tune and the turbo timer will not shut off with either pedal. There must be a difference in the ECM between the 01s and 02s? I am just trying to learn all of the differences.
#336
man it is so crazy the different reactions between different trucks running the same program... I have a HUGE difference in power between 2 and 3 and a noticable difference between ALL power levels... I never have any issue with the TT, never have any issue with rough idle, surging with the 300 is all but gone (attribute the little that remains to the mach 6.5s)
quad any insight to the differences? are the computers from these trucks really that different??
#337
I loaded up the tune off Quads website, turbo timer took like 3 min to shut off. Could not kill it with any pedal. I could blow more smoke with it. Definitely had more power on higher levels.... felt like wire tap was working, high idle kicked in.. first time ever for my truck, problem was It would not go back to a normal idle unless I put the truck on a different level. In fact, after driving for several minutes, turned back to level 0 and immediately idle came up to 1000 RPM. By the way Quad, on my rig, your high idle feature purrs so smoothly it seems as if my truck was designed to idle at 1K. Downside was on other levels, my truck got that irratic idle that have talked about. Not terribly bad banging, just a lot of up and down 100 rpm or so and a miss now and then.
Beta 300 is by far the smoothest on power delivery for me, I just hate an automatic turbo timer, wish it could be based on egt instead. I can definitely feel the lack of pump stretch on this tune, I have yet to get egt's high enough to test out the defueling and I'm about as overfueled as they come with stock turbo and hot jammer 5's. Anyway, come saturday, I'm gonna put 800 miles on this beta 300 tune through the mountains of Utah ID, MT, and WA, I can't wait to see what kind of mileage numbers I can come up with.
#340
Hmmmm?
http://cgi.ebay.com/ebaymotors/98-5-...spagenameZWDVW
Side note: What are the built in gauges like?
#341
Hmmmm?
#342
I tried everything and it was as if level zero was a constant high idle at 1K rpm, turn up to level one and idle back down to 800 ish, turn down to zero and immediately idle up to 1K. Weird. Also noticed that after truck was up to operating temp, truck started surging at idle, got really lopey etc on level 1 and up, but put it down to zero and idle up from lopey surgy 800 to smooth 1K.
Power was definitely equal to the Juice. I still can't believe how hard the lower midrange hits with such little smoke out the tailpipe.
#343
But with the other two tunes that I have tried, idle is smoother than stock at all times, hot or cold. I really think that this box could smooth out a HRVP idle.
#344
Oh yeah, the power is back but not as strong as the comp tune...no surging issues...
#345
Man where is quad?? Haven't seen him post on the Adrenaline in forever! Lots of questions unanswered, lots of changed left to be made... All kindof annoying... Hopefully he is getting stuff worked out, but it would sure be nice to have an update.......
