Quad Adrenaline Beta Testing....
Old 12-17-2007, 11:24 PM
  #316
J Lent's Avatar
Originally Posted by dodgediesel
Bnold, so far just myself and J Lent has this crazy idle issue?? I'm just waiting for a fix!!!
My truck kicked in high idle today at 26*f. I guess that was Smarty tuning, but it did cancel with the brake/gas. It would kick in every 2 minutes.
Old 12-18-2007, 12:29 AM
  #317
1-5-3-6-2-4's Avatar
got the CC charged today.......mine must me enroute. nice christmas present to me.
Old 12-18-2007, 07:00 AM
  #318
lotero's Avatar
oh man all your runnning electronics wise is a smarty?! your right this is going to be a good christmas for you
Old 12-18-2007, 09:07 AM
  #319
JIT
JIT's Avatar
This Street Tune seems a LOT milder than the original Race tune! Smoke clears up quickly even on PL10 with my Jammer 5's. I could never get the smoke to clear with the Edge J/A and these injectors. Is it possible the box isnt fueling properly?
Old 12-18-2007, 10:52 AM
  #320
lotero's Avatar
its possible, just give it some throttle and run the box through the settings to see if you feel the difference. EGTs are a pretty good indicator on if your getting fuel too.
Old 12-18-2007, 11:18 AM
  #321
yup the only electronics that have ever been on this HRVP44 is the Smarty. I've got a stealth cover waiting to go on
......its was actually the 14th the charge ran through.......so it better be closing in on the border by now
Old 12-18-2007, 11:46 AM
  #322
swmnkdinthervr's Avatar
What tune came with the box...v300? If so you may be having the issue I'm having, no extra fueling. It seems to be one of the quirks of this tune...
Old 12-18-2007, 12:12 PM
  #323
bnold's Avatar
my v300 can produce higher EGTs than my smarty TST comp stack... could never get above 1350 with the stack... with the V300 I'm able to hit 1400...
Old 12-18-2007, 12:24 PM
  #324
isbsinkinson's Avatar
is it only 99 trucks that are not getting full fuelling with the v300 tune? I have a 01 HO pump on my truck also
Old 12-18-2007, 12:48 PM
  #325
Don't know if it's only us but it seems to be prevalent on our trucks as there are several with the same issues...are you having any trouble with the TT either not shutting off with the brake/accelerator or working intermittently? Quad is aware of this issue...I'm told a new program is being worked on.
Old 12-18-2007, 01:19 PM
  #326
the tt works when it wants to. sometimes smoothly sometimes not so smooth, most of the time not at all. never turns off with either pedal. very happy with level 2 as the throttle response is great. Looking forward to getting truck back from getting trans rebuilt at garmons & even more to getting new tune from quad.
Old 12-18-2007, 05:42 PM
  #327
wurkenman's Avatar
I have no trouble with mine fueling. I feel it hit every time I push the button all the way up to level 10. This thing never stops pulling. I did not notice it pulling that much tho until I put in the bigger nozzles and upgraded the turbo.
Since I have taken possession of the Quad box, is when I did both the nozzles and the turbo.
Old 12-18-2007, 06:42 PM
  #328
wurkenman,
you have the same turbo as me & one step up on injectors, and was curious about your egt's & boost. on level 2 I am unable get it above 1200 after trans is locked up. not able to take offs from stand still because of tranny probs. If i could get you to check that out on level 2 from say 55-90 mph. when changing my turbo there was alot of grease & gook in the intercooler lines & I think I might need to flush the intercooler. On the tune that came on the box I could go over 1350 on level 3 pretty quick. I dont have any additional fuelling above level 2 & wont get truck back till later this week hopefully. thanks
Old 12-18-2007, 08:21 PM
  #329
wurkenman's Avatar
On level 2 I do not see anything over 1250. On level 10 I have to push it really hard to get it to 1350-1400. The bigger exhaust housing is the big kicker.
Old 12-18-2007, 08:35 PM
  #330
J Lent's Avatar
98.5-00 not fueling on v300 tune. My friend & I both had no luck with v300. He has a 98.5.
Quick Reply: Quad Adrenaline Beta Testing....
