Quad Adrenaline Beta Testing....
#2402
#2403
#2409
the only thing you got to watch is if you do like a burnout and let out real quick the truck will die and you have to sit there looking stupid for sbout 40 seconds
#2410
#2412
question here: if the adr is pulling every drop of fuel out of the pump, then why is it when i lug the motor without building any boost there is not as much smoke pouring out as there was when i would do this with the drag comp?
#2413
It's not. It has the capability of doing that, but that isn't good for the pump.
#2414
Quad monitors more things than edge & brings on the timing to clear the smoke. Edge didn't start adding fueling/timing till a certain boost number was seen, quad fuels as soon as he sees tps movement.
