Quad Adrenaline Beta Testing....
Old 12-09-2007, 10:14 PM
  #226
bnold's Avatar
Originally Posted by lotero
First things first, i dont show a light blue wire on the plug that goes into the adrenaline box so i tested the two royal blue ones, they are pins 15 and 31. with the truck off i get nothing through them. with the key on (plug unplugged from the adrenaline) i got 0.527, same reading with the truck running on pin 15. pin 31 showed 0 with the key on and .056 with the truck running and advanced with RPM.
the dyno day went really well there were ALOT of trucks and people, it was cold and rainy all day but fun nonetheless. i dynoed with the drag comp hooked up first it gave me 542hp, we werent able to get an optical pickup for the torque so i will calculate it. next i hooked up the adrenaline and got 541hp, that one impressed me! i figured it would be more than the drag comp but it looks like it was basically the exact same! i dynoed the adrenaline again and got 538. i was on setting 10 for both runs...
Cool to get back to back runs... On a previous software level 10 cost me over 30hp... Level 7 or 8 was the strongest... Not sure which program you were running
Old 12-09-2007, 10:16 PM
  #227
timbeaux38's Avatar
Not Bad #'s bro...... How much time between the 1st and 2nd pulls? I would think that the Quad box would have posted a bigger # if you had run it first. Congrats on the run!
Old 12-09-2007, 11:00 PM
  #228
lotero's Avatar
Thanks man yea i was excited to get the runs done same day same dyno, air pressure, fuel level... everything... i wish i would have went down a couple of settings now just to see. there was a matter of three maybe four minutes between the drag comp and quad runs, it was just a matter of changing the connectors which are still installed next to each other. time to sell the drag comp!!!
Old 12-09-2007, 11:04 PM
  #229
lotero's Avatar
drag comp sheet. 542hp
Old 12-09-2007, 11:05 PM
  #230
lotero's Avatar
quads bad *** box 1 and 2
Attached Thumbnails Quad Adrenaline Beta Testing....-541-quad1.jpg   Quad Adrenaline Beta Testing....-538-quad2.jpg
Old 12-10-2007, 08:25 AM
  #231
RowJ's Avatar
i dynoed with the drag comp hooked up first it gave me 542hp, we werent able to get an optical pickup for the torque so i will calculate it. next i hooked up the adrenaline and got 541hp......
Did you dyno with OD locked out?? Both Adrenaline runs start dropping off at 90 mph?? Edge Comp drops off even lower (86 mph +/-).
Or did you just back off the throttle at those speeds in OD?
I ask because all Dynojets I've been on, always dyno on OD.
Assuming you have 3.55 rear end, and with your 315's, 90 mph is only 2250 rpm..... well below max power??
RJ
Old 12-10-2007, 10:27 AM
  #232
lotero's Avatar
nope, dynoed with OD turned off, and released the go pedal at 3400 rpm.. im going to go drive it today and see what rpm i will be at those speeds.
Old 12-10-2007, 10:32 AM
  #233
bnold's Avatar
Dont most run in OD on Dynojets?
Old 12-10-2007, 11:24 AM
  #234
RowJ's Avatar
nope, dynoed with OD turned off....,
That would explain it. Working from memory, but 85-90 mph in 3rd sounds about right for red line rpm's.
I ran a Dynojet once in third (OD locked out). I remember it cost me some top end hp/tq, but don't recall exact amount.
Still a valid comparison between Comp and Adrenaline!
Nice job.
  #235
paulb's Avatar
Wow! Those are really good numbers for dyno'ing on a Dyno Jet in 3rd.
Paul
Old 12-10-2007, 11:53 AM
  #236
lotero's Avatar
thanks, and yea my number one concern was dynoing back to back drag comp and adrenaline.. i still love my drag comp but its getting uninstalled today..
Old 12-10-2007, 12:41 PM
  #237
J Lent's Avatar
Originally Posted by qzilla
For those of you that the V3 does not work on I need you to check on something for me.
That particular tune relies on Boost heavily. Not soley but, heavily. If the box does not see a boost signal then it won't do any fuel stretch over PL02.
So, check your boost voltage for me. Check it on the Light Blue wire and let me know what you come up with.
Either we are not getting the signal or it is possible there is an issue with the MAP sensor.
I tested my voltage from the light blue wire & it showed 0.56v with the meter set at 20. I tested it at the 3 prong flat plug going to the Adrenaline from the map sensor.
Old 12-10-2007, 02:40 PM
  #238
swmnkdinthervr's Avatar
Just got mine tested...it read out .520 Hope this helps!!!
Old 12-10-2007, 05:53 PM
  #239
J Lent's Avatar
Do you have fueling working or is your Adrenaline running in XZT+ mode also?
Old 12-10-2007, 06:07 PM
  #240
No fueling...and the TT stopped working altogether today...I'm a little concerned that this box is gonna leave me sittin' by the side of the road...
Quick Reply: Quad Adrenaline Beta Testing....
