Quad Adrenaline Beta Testing....
#2267
Is it dying when you lift or when your at WOT? If it's when you lift, how fast are you lifting? Just my experiance, but I don't just yank my foot off the loud pedal when I make an aggressive pull (mainly to prevent turbo bark), so maybe if you eased out of it that would prevent the stalling. I'd be curoius to see if that helps.
#2268
well when that happened to me i did not take my foot off the pedeal fast to keep the turbo from braking but it still died. i won't run it for no my lp cannot keep up with the fuel that it is trying to use. Justin also said that it may run the pump out of fuel also so be careful.
#2269
#2270
Anybody else have a problem with 4k test 5? I loaded it and now I cant load anything else into it. The only thing that shows up is the box s/n the rest is y's with - on top of them???????
#2271
So will the new pulse monitors all have the bigger processors in them already, and just the beta units have to be sent back? Or is that an upgrade option or something?
#2272
DO NOT USE ADR_4K_TEST5 for any reason whatsoever.
In your case you need to give me your email address and your serial number and I can restore the box.
#2273
So basically every Pulse is good to go other than the beta units. Not sure how we got so carried away with code size but, with all the added features and the tweaks we put on the menus I guess the code got inflated fast!
#2274
#2275
#2276
#2277
Can I ge this emailed to me?
BigB82789@aol.com
BigB82789@aol.com
#2278
Is the Adrenaline EGT probe reading accurately now. Vaguely remember they were reading low for a while?
I'm still using my Isspro EGT gauge but am hooking Adrenaline probe to my new LazarSmith SS air horn for IAT readings.
RJ
RJ
#2279
Has anyone ever had the box lockup on them? Yesterday I was driving along and the EGT readout stopped changing. It was froze at 1050, including at idle. I switched the readout to the PL, it showed PL08 and I couldn't change it. Also boost was stuck at 35psi(the last reading I guess). I got home and unplugged the box, plugged it back in and it worked fine again. Gotta love electronics
