Quad Adrenaline Beta Testing....
#1997
Well, another update.
We found an error in the software that is only allowing us about 75% of our fueling capabilities. Not sure how it happened but, the good news is there should be a lot more fuel available tomorrow!
The funny thing is that the guys dynoing and drag racing have had pretty good results. These should only get better now.
Look for the updates tomorrow after lunch.
Sorry!!!
Sorry!!!
#1998
#1999
Do you have a de-fueling tune installed? Realize that even though it is set at 1250 or 1150 we will start de-fueling earlier than those numbers in order to stop any overshooting that might occur. On a stock truck we can do this pretty easily but, as you add injectors and other mods it gets harder and harder. Our #1 priority is to make certain we do not overshoot, so sometimes we pull the trigger a little early to keep the engine safe. As you saw we did not just back all the way down or anything but, just enough to put the EGT's in check and keep them from hurting anything.
Soooo, if I'm reading u correctly, it may actually start de-fueling at 8-900 so it can manintain the max of 1250. Is that correct?? or do I just have a quirk in my Pulse??
New update tonite..........Yeah!!!!!!!!!
Having to remove the Pulse again.............
#2001
Did this affect the first 'RowJ' tune as well?
EGT de-fueling is the only thing that I have set. My Pulse will start flashing at around 8-900 degrees on mine. I just thought it was a quirk and was just waiting for the next upgrade to see if that fixed it.
quad would it be possible to get the rowj file to 4000 rpm mine literaly pulls awsome to 3500 then dies hard and fast with some hard core sputtering
#2003
Giddy up!
EGT is the only defueling feature set, but sometime tomorrow the truck should be seeing more boost so I can't wait to see what it does. I can already punch it at 70 and watch my rpms spike 600rpms and the speedo about 2mph
Time to swap tranny's I 'spose...
#2005
You can set one parameter to Backdown% and watch it
Thank you for clearin that up for me.
#2007
You're gong to have to take a laptop out to the truck to update it or unplug from the harness and pull through the firewall and bring inside. It has a usb port on the bottom of the display.
#2008
**** i didn't see it.. i have my pulse double side taped to the dash.. bah. my battery on my laptop is so screwed too... ok thanks.
