Quad Adrenaline Beta Testing....
#1953
#1954
well at half throttel it defantly dosent surge and hits 40 psi!, i went from 60 mph to 100 in about 5 sec the turbo lit and WOW! couldent see behind me lol but sady right after that run #4 intake rocker decided that it didnt need its bolt any more and it stripped out (that common for 105 lb springs?) so i went from 6 to 5 cylinders. and had to limp her home. once she is runing and stops finding the weak links ill get a video up. im thinking monster pump(and injectors) + adraline will be a happy couple =D
#1958
not yet jsut got it running this saterday but once the head is kosher she will hit the track and the dyno! she just keeps fighting me.. and before the adraline, the new bigger injectors, ported and polished head, exhaust manifold and the bigger turbo i got 405 hp and 1034 ftlbs with a blown head gasket..... so not shure where ill be at
#1959
#1960
It was only $8 from Express Mounts. I'm using a ball mount for my water controller.
Ok, very cool. Thanks for the link! Hard to argue with that price. May have to order one for that. If I can't find a way to configure to my liking in the truck I can always use it for my gps in my Rhino.
#1961
Well guys, I don't have springs, but I was playing around with the wastegate on my 3rd gen turbo and doing a few burn outs and launches. I can say that on my truck, there is full fueling to 3525 RPM.
I was shocked when I finished a 42 psi WOT stint and pulled up the data log. No noticeable defueling up to 3500 RPM.
#1964
Originally Posted by Quad
If the 1/4 mile stuff is working and showing 60', 660' and 1/4 mile et and MPH then it is updated.
Now just need to figure out the Tire Size thingy?
Keeps fighting me. Takes the 105.0 change, suggested by Lotero for 315's, but still reads same as my Speedo and less than my GPS???
I'll stumble into it one of these trys.
Signed: Pulse Challenged
#1965
Just downloaded the adr2006 tune and tryed it. Turbo timer would not go off and had to stall the truck out to get it to shut down. Is this a glitch in that tune? All the previous tt's worked great.
