Quad Adrenaline Beta Testing....
#1756
Is this tune only available to beta testers? If not Badams105@gmail.com. I really love this box, but the surging is pretty bad. Still having problems with power levels flashing(all except 0,1,and 2). This box is just getting better and better with every tune though.
#1757
Thanks, I got it. I'll get it loaded into the module tomorrow and give her a try and report back. This sounds really positive as Row J and I have very similar setups with the exception of how we put it to the ground.
#1758
Paul, couple of quick questions.
The surge you get, is this in any power level? What about starting at PL02? I am wondering if you can just feel where we start doing fueling or what it is you are feeling.
Second, does your truck smoke more or less. Most have reported a LOT more smoke and then others say it does not smoke at all. I am wondering if something is wrong with the update I emailed out?
I haven't really seen a change in the smoke, but I have enough air to clean up about anything the VP44 can put out. The boost and egt numbers I see are in line with what they should be. The throttle %, rpm, and boost that I saw with the ADR 2000 is the same as I see now, when building boost to launch. It's 23%, 1950 rpm, and 17psi boost. If the low end fueling had changed a lot, those numbers wouldn't be the same. It actually feels like it starts fueling on the pump wire at about 7psi.
Hope this info helps. This is the best Adrenaline tune I have tried yet.
Paul
#1759
#1760
I'd like the new tune if someone would send it to me, thanks. brianj@wasatchdiesel.com
#1761
Weird it surges on PL01 that is still a timing only level correct? Even surging on PL02 means that it's not the wire tap that is causing the surge, that's CAN BUS only fueling???
Unless things have changed????
#1762
Finally able to test the ROWJ tune. MUCH smoother. It definitly drives around much better. I am really enjoying the Pulse as well. I have a few questions on the defueling but I think I will email Quad first.
#1764
Quad, What is the max value the FP sending unit can read and what will the Pulse read up to? Since I already have a FP guage, I was thinking about using the FP feature to display transmission line pressure .
#1765
Quad, this box will tow the ---- out of a trailer. I hauled around 27000 GCW today & hit alot of hills. This box pulls like nothing is back there. That RowJ tune is wicked awesome!!!! I told you in the past that my truck would surge the turbo when hitting the fuel about mid hill in 5th gear, THE SURGE IS GONE 100%!!!! I couldn't dream of egt's this low either. 1200* tops & I was in the fuel hard going up hills from a dead stop at the bottom. Whatever you did with the RowJ tune is working. Whoever is thinking about towing performance, get the Adrenaline. WOW!!!!
#1767
First off, I want to say thank you for everyone who sent the ROWJ tune to me. Second off, I want to say holy crap!!!!!!!!! Just got off the dyno about 2 hours ago, it made 533/1085 with no surging, plus the blinking power levels is gone too. Whatever you did to this tune, you need to do to the other aggressive tunes. If I had the options of the 2025 with the fueling of the RowJ, I would be in heaven. My egts got smoking hot by the way, 1690 degrees for a few seconds I really need that Pulse monitor to ship out so I can set the egt limiter at 1500. Thanks again Quad for a great box.
Bryan
Bryan
#1768
Bryan
Bryan
That's a big jump from last week isn't it! Wow, congrats!
#1770
Can some one shoot me the RowJ file, im kinda sick of the surging issue. I would greatly appreciate it thanks. chad
cmtproduce@hotmail.com
