Quad Adrenaline Beta Testing....
#1711
Does anyone know when detailed instructions will be available...I know we're just ending beta phase 2 but it would be nice to have a instruction file we could download...
#1713
Tire correction too? Cool!
The Adrenaline is really an all in one deal.
I'm buying one.
And then a new clutch and a bigger turbo and new tires.
I really need to stop logging into DTR. This site is bad for my wallet.
I'm buying one.
#1715
Thanks for the info.
RJ
#1716
#1719
Are any of you guys running manuals getting any bucking? If i am in a high gear and try to maintain speed right around 1700-1750 ish right were the fuel comes on it does that. I am running ADR2000
#1720
Yes I have the same issue. It is very rough on the truck call them up, and they should be able to help you out. They are working on setting me up right now. Trying to smooth out the transition from no fuel to added fuel. At least that is my understanding as what they are trying to do. Also to anybody reading my truck has hardly any noticeable power on any level until that 1700rpm spot. I hear all the hype that this box has lots of lowend power and what not, "better than or equall to the smarty", but what is considered low end? My comp alone was way stronger on the bottom. That is until 1700 then the adrenaline is deffinitely stronger. When I shift with my truck I constantly fall to around 1500 loaded and unloaded and I get nothing more than a stock truck until I hit 1700 again. NO bad mouthing to Quadzillas product just want to know if I have something going on. I was under the impression that my bottom end would be way better than my comp. I'm wondering if it has to do with having the HO more timing and smaller injectors. Maybe the box works better on the SO. CUSTOMER SERVICE is OUTSTANDING Justen has been working with me one on one to help me out. Never had any company go the distance that they are going to make sure that I am a satisfied customer. Once all is figured out I know I will be 100% satisfied because it seems like they will be there until that point.
#1721
It's probably not much different than the TST Comp I run as well. Anything above 2 or 3 and it surges and stutters like mad. The aggressive tunes are going to give fits except for on the drag strip at WOT.
#1722
I know what your saying about the no power until 1700, some of the earlier beta tunes fueled hard on the bottom, i am just guessing that a little later down the line they will get back to refineing them.
#1723
I used to get some on other tunes, but majorly reduced with a test tune Quad emailed to me. Haven't tried the aggressive tunes, but I'd guess they would surge in my truck and other big injector trucks based on what I've seen in previous tunes.
#1724
Custom Tuning Menu- this means everything listed under the tuning menus.
Correct MPH - This will be listed as an additional parameter "True Vehicle Speed"
Performance Tests - this is both the 0-60 test and the 1/4 mile test.
Now, some of this may already have been finished today but, I just wrapped up a solid 10.5 hours on a dyno. So I will have to see if the new update is ready in the morning.
Now, what I would recommend is that you download any of the new tunes on the website. It sounds like you are running an older version that does not support the Pulse. All the new downloads support the Pulse.
Start there and let me know what happens. For that matter you can just download either the ADR1000 or ADR2000 as you can set everything else on your own.
#1725
