Quad Adrenaline Beta Testing....
#1592
Quad, I just tested the adr_prod_test program. First program I've run so far without any shutter or major palpatations. I got up to level 5. That's about all I can get up to around town with the 220hp injectors. I run out of real estate quickly. Not sure how strong on overall performance so far, but this is at least a jump in the right direction. Seems very, very smooth! I see a little smoke, but not bad. It was about 60 degrees in the test. Will have another outing in the truck this afternoon. Will try and report more later.
#1593
Can't tell you anything other than that, because I just don't know
#1594
Why should you be any different
I've been on the road all week and if I miss a day....it's an hr of homework! Actually, I find by just reading Quads posts, I get what I need to keep up...... usually.
Testing Pulses are out to some....all within a week +/-.
QUAD - Thanks for Fueling info. on new tunes. Will play with new Comp tune on way to Dynojet dyno (about an hr away) and then decide. Probably just run ADR2000 on PL00, 08 & 10... for honest comparison with the Dynacom Dyno in Burleson, from 3 weeks ago!
RJ
RJ
#1595
We barely even began the beta testing phase. I think there is maybe two to three monitors out there right now, with the rest (I think?) going out tomorrow? Myself and one or two others have them, and I think one of those people can't even drive their truck because it's apart?
BTW. Was there supposed to be a disc (as in software) that came with the Pulse??
#1596
Mine just showed up and I just got done installing it in the truck. I haven't been able to drive test it as I'm still technically at work. Should make for a good ride home, though. I just put a new VP in and I was gonna wait a little longer to tap the wire. But after actually getting the Pulse in my greedy little hands, pretty sure the warranty is over as soon as I get home.
#1597
Yeah it shipped tuesday from what I gathered. I thought the change was made on monday late and then they shipped out the modded ones on tuesday. The lastest ones are simply the next round... Eh either way I'm happy its in the truck.
#1599
Nice ride home. Non wire tapped, Smarty on 2. Still had good pickup. Standard Gauges seem fine. Fuel pressure still bounces around quite a bit, but I am going to add my snubber to infront of pressure sender so that it will quell the waves fromt eh VP. Now on to the other parameters. Coolant TPS Load Pretty much anything on the bus, isn't comming thru? could it be a bad connection on the Can Bus?? Other than that I love the fit and finish on the pillar and how the guage mounts into it. Also added TT and High Idle on the stock program ADR 2000 and it all works. I will test it a whole lot more tomorrow as I have most of the day off. Once again Quad another home run.
Edit: Found the problem. I was running an older software version that I was using to troubleshoot my truck when the VP let go due to the #9 fuse coming out on a WOT run. Loaded up the ADR 2000 from 3-7-08 all is well. I have all the parameters up and running. Sorry for the confusion. Always good to make sure you know what you think your running.
#1601
ill have the truck up and runnign this weekend and im excited to see what teh adraline will do. will be comparing it to the redline andim shure the adraline will whoop up some, and i got quads new comp tun for big injectors im stoaked
#1602
my roomate called me and told me i had recieved two packages from quadzilla, i think the tire marks leaving work are still smoking and i yanked all my old gauges out on the road to my house (which i dont recommend) but the pulse is installed and i will not be able to wipe this s*** eating grin off my face for at least a week, another home run quad, you guys are way way way out ahead of the rest, i havent even had a chance to go through all the options but this thing is SWEET!!!!! THANKS!!!
