Quad Adrenaline
Old 06-29-2010, 10:45 PM
Jturs's Avatar
Quad Adrenaline
well i just noticed the other day my Adr wont smoke only after i drive alot like an hour or so of highway driving even when i crank it up to pl10 thats with the 2000 tune. see it did this the other day and this morning i got in my truck and let it warm up driving around town then i put it to the floor and it smokes like it normally does which is ALOT on pl10 with same tune then after that i drove a couple hours on freeway and slowed down back in town it then does the same thing no smoke when i punch it maybe a little little puff. any ideas? another noticed this.
thanks josh
Old 06-30-2010, 05:12 PM
Jturs's Avatar
anyone?
Old 06-30-2010, 05:46 PM
motochamp250's Avatar
does it still have the same power as before when it does the "no smoking"?
Old 07-01-2010, 04:37 PM
Jturs's Avatar
Seems like it for the most part. It's weird cause there is no other symptoms or anything else acting up it just won't smoke at all. Then let it sit for a while and punch it rolls coal.
Old 07-15-2010, 11:55 AM
Jturs's Avatar
Well yesterday after my truck had been sitting all day I was driving home and no matter what pl setting it was on it wasn't changing power for the truck and wouldn't fuel like it usually does no smoke could only build 20psi of boost. Like it was stuck on pl02. So I checked all my connections and pump wire tap and was all good. So then I un plugged my adr box and plugged it back in and it was normal. Any ideas what would cause this. Bad box or what kinda worried going on a road trip tonight. Any help appreciated thanks
Old 07-15-2010, 06:36 PM
Jturs's Avatar
i know someone has got to have something to say. im kinda getting worried cause today driving i had normal power when i first started driving and by the time i got home 4 miles away it had the lose of power no smoke not building boost problem again.
Old 07-16-2010, 07:54 AM
boughtadodge's Avatar
jturs Mine does the exact same thing I talked to quad on another forum and he says it is impossible to be the 2000 tune but mine works fine on the 3000 and 1000 tunes but both of them had very little power off the bottom. So I called quadzilla and talked to jeramy and described my problem and he sent me a tune that has nasty power and does not do it or has not done it yet. I know when it does it it will drive you crazy when you need or want the power it is not there just level 2 power
Old 07-16-2010, 11:26 PM
STACKED's Avatar
try the newer 3000 or one of jeremys tunes. should fix it.
Old 07-17-2010, 07:48 AM
I tried the 3000 tune it was so dead on the bottom that I did not like it. Jeremy sent me a tune and it works great
Old 07-17-2010, 11:55 PM
granahan378's Avatar
Mine has the stock tune that came on it not sure, but on hot summer days it will do the same thing just freeze up and do nothing????And with the turbo timer it wont shutdown until you unplug the box and plug it back in. Really weird havent talked to them yet.
Old 07-18-2010, 07:58 PM
Jturs's Avatar
hmmm i dont want 3000 tunes due to egts getting to hot and all. but i just got back from a road trip and before i left i put ina new 2000 tune and it wouldnt smoke and had lack of power so i came back home put back in the other tune i had before and it worked fine smoked had power and all then about after an hour of driving lack of power again and it would keep working then not working and back and forth. my turbo timer still worked all the time and the 1250 egt defuel still worked. i also dont think it was heat because where i was driving was about 60 degrees or colder. is this what your tuners are doing. it is all just weird cause i never had a problem for over 2 years until now.
Old 07-19-2010, 08:58 PM
CummapartFrk's Avatar
I have the same tuner and have had similiar problems with mine. It ended up being the box itself. Been through 2 boxes now. Quadzilla is very helpful and quick with their replacement parts. I would suggest asking them about repalcing it.
Old 07-20-2010, 10:10 AM
Jturs's Avatar
I contacted quad and I need to send it in for updates. So I will.send it in and keep it posted what's going on with it. Can I.run the truck with the box disconnected?
Old 07-20-2010, 09:28 PM
I had to disconnect it completely. Like the truck was before I put it on. Luckily its not that hard to connect it.
Old 07-20-2010, 09:33 PM
You think your truck runs good with it now. Put a turbo and some injectors on your truck and you will really appreciate it.
Quick Reply: Quad Adrenaline
