Quad Adrenaline
The Adrenaline works fine without either hooked up. The only things you will miss out on are EGT defueling, EGT turbo timer (if/when it becomes available) etc... I have been running my beta version without the pyrometer or fuel pressure connected since October.
Len
Len
You can also hook up two EGT probes--one before and after the turbo.
IMHO, more gauges are always better.
I kept my analogs for now, I just hooked the mechanical egt gauge by splicing it into the Adrenaline egt sensor. The fp gauge I hooked inline with a tee fitting & the Adrenaline sensor into the vp44. Check out where I mounted my controller. Attachment 19534
I have this fitting http://www.vulcanperformance.com/ser...gree-08/Detail at the vp44 & the Adrenaline sensor threads into it. Then close to the firewall, I have the mechanical gauge tapped into this. http://www.vulcanperformance.com/ser...-fdsh-2/Detail
__________________
__________________
