Is the Quad Adenaline avaliable yet
I was going to try the Quad Adrenaline,does anyone know if its available yet?And will it help any on my egts while towing? Right now I hit 1300 fairly quick towing which I do alot.I am running Mach 2.4s and a EZ with stock turbo and Scotty 2 for airbox and 5 inch exhaust. Love my setup but would like to jump up alittle and keep stock turbo for now.
It will be available soon, but not sure when. The Adrenaline has egt control set at 1250*, it will be the best towing box built for sure. I haven't tried the egt control towing yet, but guys have said that it is smooth & keeps it at 1250*.
Set the de-fuel to 1250 (download the 1250 defueling software which is how it comes anyway)
Run in PL01 which is timing and boost fooling only. This will probably be worth around 40-50hp with your injectors. The timing will help egt's when you are towing. If you happen to bump the 1250 range the Commander will de-fuel down until it is only doing boost fooling.
Now, the only downside is that it cannot de-fuel any less than just your injectors and boost fooling. So whatever that is on your setup will always be reachable.
Now lets say that your truck will hit 1250-1300 with just injectors and boost fooling. The cool thing is that the de-fueling works so good you can set it to PL10 and drill it and you will not see over 1250-1300deg no matter what. It also does not just turn off, it adjusts the power down in 1% increments. It is so smooth it does not even feel like it is working you just have to watch the egt gauge to believe it!
If you get an Adrenaline and are having egt problems already here is how you need to run it.
I have no earthly idea. I always tell people to talk to Lary here at the DTR store. There are also some other great vendors you can find if you want someone local to do the install.
The Adrenaline boxes should hit all dealers about the same time.
So when is it to be released for sale to the public?
I don't have an exact date on that yet. I am working on getting all the beta guys taken care of. I have to make sure all of them have properly working product or at least an extremely high percentage of them like 98-100%.
Once that is done we should ship within a couple of days. I am just not sure exactly how long that will take.
jmccart
05-04-2008 07:49 PM
P.J
10-13-2006 01:54 PM
jmccart
10-12-2006 01:19 PM
hllbllyhellion
08-19-2006 06:18 AM
