Pyrometer readings
Re:Pyrometer readings
Yes I have the EV model, but my amplifier box is green. I don't think you can go wrong with the wire length with the EV since the box has the wire attached and therefore comes with a fixed length.
KATOOM: - I read the instructions as follows: The variable length leadwire on the probe is terminated by the connectors.
I think that since I didn't cut any wire anywhere there shouldn't be a length issue. Got the stuff as a set.
ISSPRO R3607TR (EVA Pyro2 1/16" 1500FS)
ISSPRO R658S (Thermocouple adjustable short)
Does that fit together?
Can anybody tell me what type of thermocouple this is and how to measure it?
Thanks!
AlpineRAM
Thanks!
AlpineRAM
KATOOM: The news from Wildcat are that ISSPRO says that my amplifier box must have gone haywire. As I stated the pyro started waving at me with just the ignition on engine not running.
I stated the part number on the box that includes the gauge and the amplifier box with the fixed wiring harness, and the number of the pyro probe with the leadwire.
I do think that all the probes with their respective leadwires should give the same output on the contacts to make it possible to use the same amplifier and gauge with different probes. (My assumption since there is no mention of different amplifiers or gauges on the isspro website, they state that you need one of the probes for the gauge-amplifier combo and do not differentiate between different length leadwires for the amplifier or gauge)
Anyway, thanks for the good infos!
Rod from wildcat is taking care of it right now, I hope it's just swapping parts. I think that it's funny that the one bad pyro is the one with the customer furthest away ;D
AlpineRAM
AlpineRAM
[quote author=AlpineRAM link=board=7;threadid=22798;start=15#msg214789 date=1069924146]
AlpineRAM
[/quote]
AlpineRAM, the thermocouples used are "K" type thermocouples, and are standard units. You can even buy a digital readout for them from Fluke and other instrument companys. I have the adapter for my Fluke meter and a "K" thermocouple to use when testing new engine installations. Something like this will let you test your probe if you should need to, but it sounds like you've got it covered now!
AlpineRAM
[/quote]
Thanks Hammer!
I'll look in my box whether I have or haven' t got the adapter for a K-type. ;D
I think that wildcat is great to deal with. Only trouble is that sending stuff takes some time and lots of cash. And a store visit would be quite expensive ;D
AlpineRAM
AlpineRAM
