Pyrometer Probe
Pyrometer Probe
I had a garage install my pyro probe the other day. I didn't look at it till I got home and they installed it post turbo. I called them about it and they said that where they installed it the temp. reading is the same as pre turbo. Can this be correct? I have a 2001 Dodge 2500 Diesel with auto. I have Autometer gauges.
Wrong. The temps will be 3-400 degrees lower post turbo. You could have them put a brass pipe plug in the hole they drilled and have them redo it pre-turbo. I sure would.
Originally Posted by Mike D
If you add bigger injectors down the road the difference will be closer 600 degrees.
Sometimes it may not even be 100 degrees.
Other times it's well over 500°.
Post turbo isn't that much better than none at all, because by the time it shows dangerous temps, the damage is done.
jh
Thanks everyone. I went back to the garage this morning an told them I didn't agree with them. They are going to move the prob to pre turbo next Thursday. Will post the difference I see then.
Just tell them to follow these instructions. http://www.piersdiesel.com/TechPyroInstall.htm
Originally Posted by HOHN
See my gallery for "proper" location of pyro probe (as far as I know)...
That way when you drill the chips fall right out!
I'm kidding of course. Hohn has is right check his pics. Cute kid too!
Highland joe
18
02-19-2007 06:26 PM
TinJim
26
09-19-2005 11:58 PM
