pyrometer issues
pyrometer issues
i just got my gauges in today
autometer phantom II series trans boost and pyro
now the pyrometer setup from this kit is strange
you drill and tap the manifold like always for npt fitting.
the probe slides through the npt fitting and is held in place by a set screw in the fitting
it looks like this setup will not seal and i dont want an exhaust leak from somthing that stupid
does that setup sound like it will work.
iv never seen it setup that way
ive put a pyro in a 12v and a 06 common rail and both of those used a probe with a flare nut style fitting that sealed when tightened
any thoughts
any thoughts
it wiggles enought to know that bacpressure will surley blow that thing out
the directions are also saying to install after the turbo where backpressure is no where near as high
basiccly i think they gave me the wrong thermocoupler
ill probly have to get a different one sent to me but any other info from you guys would be great
My Pyro is exactly as you describe with the set screw on the side. It doesn't leak. Don't ask my how it seals (I thought it would surely leak) but it does seal.
Install it and go on to more important worries.
JMO
JMO
Hummin Cummins
24
02-24-2003 11:35 AM
