Pyro Troubles
Old 04-03-2005 | 08:33 AM
4RGSP's Avatar
Pyro Troubles
Has anyone else experienced this.
I have a Autometer Pyrometer. I can go along for a week or two and everything goes great. Then all of a sudden the needle jumps around, might even quit for a while. Then, it will come back on and run for another week.
I went back and checked all of the connections to make sure there wasn't a cold solder joint. Everything is good from that end.
Any thoughts?
Old 04-03-2005 | 08:56 AM
Have you tapped on it to see if that wakes it up?
Next time it craps out, check to make sure that there's power to the gauge.
If you tap on the gauge and it comes back, it's a flaky gauge. AutoMeter has pretty good warranty/customer service, call them and let them know you're having problems.
Old 04-03-2005 | 11:26 AM
coiler33's Avatar
Check the two wires where they screw together the screw from one maybe cutting into the other causing a short. Also check your power source wire, may have bad connection due to the size of the wire.
Old 04-03-2005 | 12:47 PM
dssimecek's Avatar
My autometer pyro have to have the radio power on for it to work, and then it works ok. Thin someone, not me, hookedc it up rong.
Old 04-03-2005 | 09:58 PM
4RGSP's Avatar
I only live 50 miles from Autometer. The last time I had a problem with a gauge, they told me to come over and they would exchange it for me. So, from that stand point they do have good customer service.
Old 04-04-2005 | 09:41 PM
bmoeller's Avatar
Do Autometer gauges use an amplifier box, same as Isspro? I had a similar problem with my tranny temp guage. Had a couple of loose conections on the box. Tightened them up, all good.
Old 04-05-2005 | 08:29 AM
4RGSP's Avatar
Autometer's amplifier is in the gauge itself.
I spoke with Autometer yesterday and they said the problem could be in thermocoupler or quage. They wanted me to run the truck with a voltmeter attached to the thermocoupler and watch the mili-volts. (this will be a trick). If the voltage starts to jump around then it is the thermocoupler. If not, then it is the gauge.
I hate all of this diagnostic bull####. What ever happened to install and go?
DF5152
05-12-2003 01:53 PM
Nicholas
01-11-2003 12:09 PM
woodpecker
12-20-2002 10:40 PM
nascar22
12-19-2002 11:25 AM
Stevie G
11-05-2002 08:56 AM
