pyro probe on ats manifold with twins
getting ready to do twins on dad's truck and just wondering where to mount the pyro when you flip the manifold upside down on top or bottom? also, does it matter? thanks!
I flipped my manifold for twins and the pyro is on the underside. It still seems to be giving the correct readings between the 2 guages that i've tested.
brandon.
brandon.
It's kind of up to you, some have put it on the bottom as the hole was already there and some have put a hole in the top, it doesn't really matter just put it in the correct spot and monitor the aft cylinders.
Jim
Jim
Its probly just a matter of convenience(sp?) of being able to get to the thermo to replace or test etc. But, i guess they dont get fooled with much anyways so.
TRYINGTORECOVERFROMLASTNIGHT ------>Jake
06Cummins
05-23-2006 11:58 AM
