Pyro differences??Help!!
Just installed my triple pillar gauges everything is good except on my pyro gauge it runs 150-200 hotter than what my edge juice says. I drilled and tapped this pyro pretty close to my other one. there both pre turbo on the manifold on the firewall side. can i fix it or is it a faulty thermo couple? thanks
well its hard to say really which one is the wrong temp is the new one hotter or the old one colder? i would say leave it cause the juice will defuel once you hit a certain egt so if the juice thermo is lower means you'll be able to fuel longer. but i would find another thermo to get a third reading on the temp.
just to let you know i also have about 100-200 * difference between my juice thermo and my autometer thermo. but i have my autometer thermo in the back three cyc. and the juice in the front three cyc.
dieselfuelonly
04-03-2007 12:01 PM
GreyBoy
20
11-01-2003 03:47 AM
FiverBob
12-29-2002 07:36 PM
