putting in rip exhaust and new optimas...
putting in rip exhaust and new optimas...few questions?
just got my rips 4" aluminized system with a walker 30" muffler and 4" resinator the goal making the truck quiet[as possible]....ya i here you guys laughing now...but seriously should i weld this stuff together vs using the clamps???maybee weld just some of it???i,m also putting in optima 34/78 red tops and i know about the long stud hitting the wire bundle but are there any probs with just unhooking both and reinstalling the new battery's???didnt get my dd2 and fass2 [maybee monday]..any info would help...brad
just got my fass 2 ,looks like a quality kit,good time to replace the batterys since the fass hooks up directly to them and i,m going to run the edge comp ground straight to the battery..whats the 4" exhaust worth in hp alone???
Local muffler guy tack welds the joints when using stainless band clamps. He says the pipes will rotate on the joints. If you want to change something it is easy to grind the tack weld. I also paint the pipe with anti-seize at the slip joints and under the band clamp.
If using guillotine or saddle clamps you don't need to weld.
One of the hot rod shows on the Speed Channel did a dyno before and after a larger exhaust system. The peak hp didn't change, but the curve did lift by 10-15 hp in other rpm bands.
D45
13
08-05-2008 12:34 AM
Common
07-20-2006 06:38 PM
