Putting a Locker in
Old 05-06-2008 | 09:20 PM
mxyoest29's Avatar
they are 3.55s
Old 05-07-2008 | 07:58 AM
olddodgetruck's Avatar
everyone is making a bigger deal out of it then it is. all you are going to need to do is shim the carrier side to side. put the shims on exactly like they came off your old carrier. if the backlash is to tight shim the carrier away from the pinion. if its to loose shim it twards the pinion. you can use paint to check the gear lash. do a search on the internet im sure theres pics of what your looking for. then last make sure you put the caps on the same way they came off
Old 05-07-2008 | 08:36 AM
wildmanben's Avatar
If its still stock right now, the shims will be a single cast on each side that go between the bearing cup and the housing. If you have to shim them, you will have to put shims between the bearing itself and the carrier. Takes some time to do that. Add shims, sutff it in the housing, measure, pull it out, pull bearings, adjust shims and repeat. Takes a while but not that hard. Shim kit from Dodge was $23. Spare set of bearings that I machined the centers out about .010" was another $60 to slide on and off easy for measuring shims. Then you put the new ones on that arent machined out.
Old 05-07-2008 | 10:28 PM
stuckey200224's Avatar
Originally Posted by wildmanben
Why wont it work? I got one in mine and it works just fine.... Oh and I installed it myself without a spreader.
trachtech does not make a (detriotlocker) for a dana 80 with 3.55 gears the only one they make is for the 4.10 and lower carrier. they do make gear type limited slip for the 3.55 carrier but no locker.
Old 05-08-2008 | 03:26 AM
mxyoest29's Avatar
well i took everything apart today to make sure i order new parts for the one damage......Now i did find a problem how come detriot doesnt sell a locker for my size...3.55...35 slpine...just seems wierd....so i guess i am stuck with the tru trac how are they are they loud and will they work with 35s
thanks
Old 04-06-2009 | 11:38 AM
SkyHarborCowboy's Avatar
Originally Posted by stuckey200224
you do not need a housing spreader to get the carrier out. all you need is 2 pry bars 1 on top and 1 on the bottom and it will fall out. what gears are in you truck if its 3.55 the detriot locker wont work.
What is the reason that you cannot run the 3.55 with a Detroit Locker? What are the gear ratios that are available to run the Detroit Locker?
Joe
Old 04-06-2009 | 11:39 AM
If no locker is available for the 3.55 gears what is the strongest Limited Slip Diff you can run in a Dana 80?
Old 04-06-2009 | 12:17 PM
kennyblatz's Avatar
has anyone tried this? http://www.richmondgear.com/powertrax/lockright.html
Old 04-06-2009 | 12:44 PM
http://www.xtremeterrain.com/dana803...powertrax.aspx
How many splines do our (Mine 1999) Dana 80 axles have 35 or 37?
Joe
ChrisG
27
02-26-2019 02:09 PM
mhuppertz
01-28-2008 10:48 PM
nfsommer
27
03-16-2007 04:35 PM
bsummit
08-31-2003 11:06 AM
Extreme Diesel
12-02-2002 12:20 PM
