pusher pump relay excite
where is a safe place to get power for my pusher pump relay? off the stock LP? or off the PDC some where? I want some where that it will only run when my stock LP runs and I can still use my turbo timer
Thanks,
Mark
Thanks,
Mark
you can use the asd relay in the pdc as told to me by haulin in dixie or use the hot wire to the lp, if you use any always on or ignition switched power it will start hard
midwestdually
15
12-17-2004 08:52 PM
mazeppa
02-10-2004 06:54 PM
