Pump plug
Pump plug
Ive been searching around on the web some but have had no luck finding the bigger front plug for my pump. I want to go ahead and put one in before I put the pump back on. Where can I get one??
You should be able to get it from a pump shop if not a pump parts/Bosch dealer should have one. If you look through this link you can find the part number. http://www.cumminsforum.com/forum/94...ight=nice+rack
i think its like a 2095 or a 3095 for a part number
i put one in while i had my motor out....
pin the pump, pop the front gear off. unbolt the 4 bolts on the pump and the one bolt below the pump (its a supporting bracket) and just slide the pump about an inch or so backwards and that gives you enough room to work
jlipskoc
02-21-2007 12:13 PM
banks twinram
02-02-2005 02:24 PM
