Pulse quit working
Old 11-18-2008 | 10:06 PM
isu elvi's Avatar
Pulse quit working
Having an issue with the Adreniline/Pulse unit on my 99. Left the house yesterday morning at 4, drove 2 hours, everything worked as usual. Shut truck off in parking lot of the convention center for a meeting I was attending, and left it. Got in the truck at noon to go to dinner, truck works fine, but nothing works on the Pulse. It lights up, and you can get into the menus and such, but all of the numbers are 0: EGT, boost, oil temp and water temp, and the setting. Started truck to go to leave at 7 pm, and same thing, nothing. I looked under the hood at all the connections, but cant see anything that is unhooked or out of the ordinary. Before this, other than a push button issue that Quad replaced, unit has been working flawlessly for about 6 months.
Anybody got any ideas on why or even where to start working? I was going to email Quad in the morning, but thought I would start here. Thanks,
Old 11-18-2008 | 10:14 PM
J Lent's Avatar
Unplug & reconnect the pulse from the harness under the hood.
Old 11-22-2008 | 07:08 PM
isu elvi's Avatar
Hey it worked, well sort of. Guages worked, and was able to set a power setting, but my Warm Up didnt activate, nor did my high idle, which I went in and set right after plugging everything back in. Got any ideas?
Old 11-22-2008 | 07:16 PM
BigB82789's Avatar
Call quadzilla.
Old 11-23-2008 | 09:48 AM
gwhammy's Avatar
I've had this random problem from time to time,start it up and nothing. I reprogram the adrenaline and everything works for a month or two. I'm thinking calling quad and see if they will look at it.
Old 02-14-2009 | 11:26 AM
EBunger's Avatar
What ever happened did you get this resolved?MIne is doing the all 0s thing unplugged and plugged back in Nada.
Old 02-14-2009 | 06:54 PM
JoeCanuck's Avatar
I had the "all zeroes" thing happen to me once. I unplugged/replugged the connection to the ADR module and it's been working fine since.
I don't recall if this was before or after updating the ADR and Pulse.
Old 02-14-2009 | 08:57 PM
EBunger's Avatar
Yep that did it thanks.
STACKED
01-22-2009 01:07 PM
Tingram
10-13-2008 12:24 AM
j28s
05-26-2004 04:02 PM
j28s
05-24-2004 09:34 PM
Garz
11-17-2002 03:02 PM
